colortune
Old Mar 7, 2003 | 02:07 PM
1977's Avatar
1977
Default colortune
Hi Guy's I have just finished putting in my new cam and new Headers. I was wondering if any of you have used the ColorTune to set up your carb and if is worth the time and money thanks for the replies :thumbs:
Old Mar 7, 2003 | 09:25 PM
DaveL82's Avatar
DaveL82
Default Re: colortune (1977)
I haven't used one in ages. It was great for tuning my old MG's with SU carbs. Should work on the vette it you can get access.
Dave
Old Mar 8, 2003 | 08:34 AM
ram82fire's Avatar
ram82fire
Default Re: colortune (DaveL82)
I use a color tune and they work great ! I run 4 dcoe weber carbs on a moon crossram intake with individual runners to each cylinder . This allowed me to make the desired changes to each individual cylinder . It is a bit of a pia but the results were well worth it !
Geo :steering:
Old Mar 15, 2003 | 10:35 AM
Matt Gruber's Avatar
Matt Gruber
i've been successful with an O2 sensor at each cyl. see link in sig. for details.
Question: how do you test WOT with a colortune?
Have an assistant hang on to the fender as you floor it? :lolg:
Old Mar 16, 2003 | 06:02 PM
L79vette's Avatar
L79vette
Default Re: colortune (Matt Gruber)
Colortune would work on a chassis dyno. I'd wonder if you could see it well enough, though.
Old Mar 17, 2003 | 07:52 PM
ram82fire's Avatar
ram82fire
Default Re: colortune (L79vette)
Yes you will be able to see the color tune with the attachments that are supplied . Matt your point is well taken regarding the the use of sensors but,,, I really donot want to hack up my headers for each cylinder to tune a IR system . More people should read your tuning tips as they are a very good info resource .
Geo
Old Mar 18, 2003 | 10:47 PM
L79vette's Avatar
L79vette
Default Re: colortune (ram82fire)
Here's an alternate method for using the colortune to set WOT mixture:
http://www.niksula.cs.hut.fi/~mdobru...iy/10/dyno.htm
This from the normally-sane David Vizard, the same guy who writes deep technical articles for Circle Track magazine. I don't want to be within 500 feet of a jacked-up car running wide-open throttle up against the brakes.
Old Mar 19, 2003 | 07:57 AM
Matt Gruber
i'm sure glad i wasn't born yet when that article was written :D
Thanks to Vizards recent book(1996); that's where i learned to use an oxygen sensor.
tips in my sig.
To colortune
