Dynamic Compression Ratio Post ???
Old Mar 29, 2003 | 03:10 PM
CFI-EFI's Avatar
CFI-EFI
Default Dynamic Compression Ratio Post ???
Some time ago, in the not too distant past, a link was posted to a calculator for calculating dynamic compression ratio (dcr). I downloaded that calculator, and know my dcr. However, there were also guidelines as to what was safe or reasonable for specified applications. Can anyone recall or direct me to those guidelines? I am interested in installing a smaller cam, but I am afraid I can't go much smaller.
RACE ON!!!
Old Mar 29, 2003 | 03:23 PM
LD85's Avatar
LD85
Default Re: Dynamic Compression Ratio Post ??? (CFI-EFI)
Heres one I use, may not be the one you are looking for! http://www.empirenet.com/pkelley2/DynamicCR.html
Old Mar 29, 2003 | 04:54 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Dynamic Compression Ratio Post ??? (ld85)
That is EXACTLY the site I was looking for. When I first went there, I down loaded the calculation program, unzipped it and have it on my hard drive, but his dissertation isn't there. Thanks to you, I have now down loaded the whole page, and I can finally make some sense of my numbers. It looks like I have a LOT of room for the smaller cam, that I think I need. Thanks, and...
RACE ON!!!
Old Mar 30, 2003 | 01:31 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
without a knock sensor in your engine i do not know how you would know for sure if this theory works. :chevy
Old Mar 30, 2003 | 06:41 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Dynamic Compression Ratio Post ??? (clem zahrobsky)
I think it is more than just "theory". Possibly, the exact DCR ratio tolerences for different gasolines vary for different engines and conditions. Currently, I am way below the 8.3 street/premium limit. I feel I will be better served by a smaller cam, and it appears my engine combination will allow it. By the way '84's came with knock sensors.
RACE ON!!!
Old Mar 30, 2003 | 07:17 PM
clem zahrobsky
Cruise-In I Veteran
a lot of things enter into this,fuel ditribution,temp,deposits in the chamber,sharp edges and even excess oil in the combustion chamber. :chevy
Old Mar 30, 2003 | 08:27 PM
CFI-EFI's Avatar
CFI-EFI
I don't argue with any of that. This is a new engine I purchased. I have disassembled it to inspect and reassemble so *I* know how it is put together. There are no sharp edges, no carbon, oil is expected to be minimal, and operating temps will have to be determined. I have had the block decked (yes, on a new engine) and raised the cr, slightly. I have long felt the cam was too "big" and the dcr numbers prove it. Any/all guidence is welcome, but meanwhile I'm looking for a smaller cam. Thank you for your interest and concern.
RACE ON!!!
To Dynamic Compression Ratio Post ???
