Proform center section?
Old Apr 1, 2003 | 09:46 AM
INMYBLOOD's Avatar
INMYBLOOD
From: The problem is all inside your head she said to me.
Default Proform center section?
Has anyone used this and proven it to help? What about just milling off my choke tower and removing my choke blade? Will that help or could it F*&$% things up more than it can help. I am more than competent at machining just have never really got any good responses about doing this mod on a carb. How much might be gained by milling and removal of the blade? Why I think it might help is because of the fact there is "very little" room between the top of my choke horn and the bottom of my air cleaner because I have low hood clearance. So I was thinking this would give it more room? Is this sound or just grasping at straws?
Old Apr 1, 2003 | 12:29 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default Re: Proform center section? (INMYBLOOD)
List you motor combination
Old Apr 1, 2003 | 02:42 PM
INMYBLOOD's Avatar
INMYBLOOD
Default Re: Proform center section? (69 N.O.X. RATT)
350+.040
650 DP
edelbrock performer
041 castings screw in studs 2.02/160's
Comp 280 230@.050
KB hypers not dished just valve reliefs
Gm rods ARP bolts
GM 4 bolt block 3970014, GM forged crank
1 5/8 headers, 2.25 exaust until exit of mufflers then 2" OD to fit out bumpers
EDIT: I don't know if you want a real world idea of what this has done in the past but it usually will push me to low 13's on regular street tires. Best of 13.10 at 105.7 Thanks for any comments.
[Modified by INMYBLOOD, 1:46 PM 4/1/2003]
Old Apr 1, 2003 | 07:42 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I'm using the Proform 750 body on what started out as a Holley 3310. I, like you needed underhood clearance. Ironically it ran great for anout a year and 1,800 miles or so. Then last week it started dumping gas & floofing. I don't know it it's Proforms fault or not.
Looking back, I shoulda opted for a new HP Proseries Holley. They're the one's without the choke & choke tower.
Here's mine:
Here's the one I shoulda bought:
Here's the description: http://store.summitracing.com/partdetail.asp?part=22203
Old Apr 1, 2003 | 09:42 PM
L79vette's Avatar
L79vette
Removing the airhorn may be useful in increasing flow, especially with a lid close to the choke horn. It should not hurt anything, other than cold weather warm-ups.
Can't say how close your flow would be to the HP carb or Proform body. I have the 650CFM 4150HP, and like it a lot. They are pricey, though.
Here's a thread from another board on this subject: http://www.chevytalk.org/threads/sho...rue#Post381097
To Proform center section?
