Hyd Roller Cams for street engines
Old May 14, 2003 | 02:35 PM
clearrun's Avatar
clearrun
Default Hyd Roller Cams for street engines
I am putting a 67' 427 390 HP engine back together and considering an aftermarket cam. All other components are stock. I understand that a street hyd roller will give me about 20 extra HP. Since I need to buy a whole new valve train anyway, I was considering springing for the Hyd Roller. Is any one using a Hyd Roller in a Gen IV BB? Is +20 HP a reasonable expectation? Is there any special machining I must do on the block to install an aftermarket Hyd Roller? Any recommendations on which one to use? 67' vette with 4 speed and 3:73 rear end, driven for fun on weekends with an occaisional trip to the 1/4 mile.
Old May 14, 2003 | 02:51 PM
John W's Avatar
John W
Default Re: Hyd Roller Cams for street engines (clearrun)
I think that you will be able to use a retrofit style hydraulic roller lifter, like these http://www.compcams.com/catalog/258.html part 854-16. The retrofit lifters seem to use a tie-bar inplace of the valley spider for retaining the lifters. It doesn't look like any special machining is required.
You will also need a cam button of some sort to control forward movement of the cam, this also requires a stout front cover or a water pump with a reinforcement that places pressure on the front cover.
What are you looking for in a cam? What other "mods" are you making to the engine (porting, intake, etc.)?
John
Old May 19, 2003 | 07:55 PM
PartTimeGenius's Avatar
PartTimeGenius
IIRC, the billets used for hydraulic rollers are different from standard cams, and normally require a change of gear on the distributor. Just another detail to keep in mind...
Old May 19, 2003 | 10:00 PM
norvalwilhelm's Avatar
norvalwilhelm
I'm running a solid roller from comp cam and have no problems with their lifters after 5 plus years. The hydraulic's are the same only internally different. As for the distributor gear after going through a few bronze ones I talked to comp cam and found out the stock steel gear is fine. I have been running the stock gear for 2 year now.
To Hyd Roller Cams for street engines
