Do I need a cam button?
Old May 13, 2003 | 12:51 PM
ldyoung's Avatar
ldyoung
Default Do I need a cam button?
I'm making my list of parts for a fresh 355 and noticed this thing called a CAM button in a Jeg's mag. I'd didn't see one when I tore down the old block. What's its purpose? Jeg's has a long style and a short style. What's up with that? I'm planning on using a 262H cam with Dart 180 heads and Edelbrock EPS intake :cheers:
Old May 13, 2003 | 10:01 PM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: Do I need a cam button? (ldyoung)
Normal flat tappet cams both hydraulic and solid are ground with a slight tapper on the lopes that push the cam towards the back of the block so no cam button is required.
Roller cams are ground flat and the cam tries to walk out the front of the block so a cam button is required on the end of the cam to keep the cam in the block. The button rides against the timing cover.
You do not need a button on your cam.
Old May 14, 2003 | 08:38 PM
ldyoung's Avatar
ldyoung
Default Re: Do I need a cam button? (norvalwilhelm)
Danke ! I really appreciate your help. :cheers:
Old May 16, 2003 | 05:25 AM
Stinger66's Avatar
Stinger66
Its true you shouldnt require a cam button, but on all my engines I have the block machined behind the camgear to fit a Torrington thrust style bearing and races to prevent the cam gear from dragging against the block. Works great.. :steering: :steering:
Old May 16, 2003 | 04:58 PM
norvalwilhelm
Default Re: Do I need a cam button? (Stinger66)
I drill a 1/8th hole behind the cam gear into the oil passange to lube the interface between the block and gear.
Old May 20, 2003 | 12:39 PM
zZArAZz's Avatar
zZArAZz
When I assembled my 505 I bought a edelbrock aluminum timing chain cover. My cam slid back and forth at least a half inch before installing a cam button. The one I bought was a roller bearing model and was too long to fit beind the timing cover.
I then purchased a plastic one and ground it down to fit.
I think for 5 dollars you might as well install one. Slide your cam back and forth after the timing chain is installed and you will see it has a ton of travel.
I would think exessive end play would affect your timing accuracy?
I am no expert:)
To Do I need a cam button?
