engine math
Old May 14, 2003 | 05:18 PM
Todbo's Avatar
Todbo
Default engine math
can anyone post the formula for determining displacment in a bored over engine? Thanks
Old May 14, 2003 | 05:48 PM
Chuck Harmon's Avatar
Chuck Harmon
Default Re: engine math (Todbo)
Pi x r squared x stroke x number of cylinders
i.e. 427 BB = 4.25" bore, 3.76" stroke
3.142 x ((4.25"/2)squared) x 3.76 = 53.347 cubic inches per cylinder
53.347 x 8 = 426.778 cubic inch engine displacement
Chuck
Old May 14, 2003 | 06:41 PM
Todbo's Avatar
Todbo
Default Re: engine math (Chuck Harmon)
Thanks Chuck , so if I want to figure the .040 over 427 I would replace the 4.250 with 4.29 in the formula and that would give me the corrected displacment. :cheers:
Old May 14, 2003 | 08:29 PM
Chuck Harmon
Yep, you got it. I hate to bore more than I need to, but increasing the bore (unlike stroking) does increase your horse power. "When in doubt, bore it out!"
Chuck
Old May 14, 2003 | 09:32 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
bore diameter X bore diameter X.7854 X stroke X 8 = CID
Old May 14, 2003 | 09:53 PM
CFI-EFI's Avatar
CFI-EFI
Pi X [rXr] X stroke X no cyl.= CID
bore diameter X bore diameter X.7854 X stroke X no cyl = CID
These are both valid formulae for the volume of a cylinder (engine, w/X no cyls.). I remember the pi X r version from 8th grade geometry. The volume equals the area of the base times the height.
Chuck
HUH???
RACE ON!!!
1984 Crossfire
Member NHRA
Old May 14, 2003 | 10:17 PM
clem zahrobsky
Cruise-In I Veteran
Default Re: engine math (CFI-EFI)
nhra and nascar use the bore x bore x.7854 x stroke x number of clys to determine the displacement. :chevy
Old May 23, 2003 | 03:18 AM
blackLS1's Avatar
blackLS1
Default Re: engine math (clem zahrobsky)
What about to determine CR?You go by the deck hight and pistons and combustion area of the heads correct?But what would the formula be?
Old May 23, 2003 | 11:40 AM
clem zahrobsky
Cruise-In I Veteran
Default Re: engine math (blackLS1)
go to http://cochise.uia.net/pkelley2/crc.htm :chevy
To engine math
