Filed Syncro Teeth
Old May 18, 2003 | 12:58 PM
Hershey's Avatar
Hershey
Default Filed Syncro Teeth
Helping a friend put together a 71 Z28 with LS6 and M21. In the trans, every other syncro tooth has been filed for drag racing. How will that effect driveability on the street? At lower RPM's will it grind when shifting gears? Thanks, Hershey :chevy
[Modified by Hershey, 12:59 PM 5/18/2003]
Old May 18, 2003 | 06:34 PM
redvetracr's Avatar
redvetracr
Default Re: Filed Syncro Teeth (Hershey)
Hershey,
That is known as a "crash box" shift it real fast up through the gears and it will probably be no problem BUT downshifting might be another matter.
...redvetracr
Old May 19, 2003 | 06:59 PM
arnold's Avatar
arnold
Default Re: Filed Syncro Teeth (redvetracr)
Hershey, that is known as a "crash box" shift it real fast up through the gears and it will probably be no problem BUT downshifting might be another matter.
...redvetracr
When I used to mod 4 speeds, I didn't find a need to grind every other tooth of the syncro rings. I could eliminate their function altogether while upshifting, yet retain their full use/function for downshifting by grinding the slots (for the dogs) so the synchro teeth lined up with the gear teeth. After this mod however, there no longer was such a thing as a (clean) 'granny' shift. The faster you shifted, the better it liked it.
Old May 20, 2003 | 04:25 PM
Hershey's Avatar
Hershey
Thanks for the help guys. I had heard of this mod, but never actually experienced it. This is primaryly a street car, but may see a little action, so we needed to know how it would act on the street. Thanks for the help. Hershey :chevy
[Modified by Hershey, 4:26 PM 5/20/2003]
To Filed Syncro Teeth
