Modifying a Toyota engine? 2F2F Style
Old Jun 6, 2003 | 08:30 PM
Monty's Avatar
Monty
Default Modifying a Toyota engine? 2F2F Style
Just remember, the youth are our future!
http://celica.net/cgi-bin/ultimatebb...c;f=6;t=009656
Old Jun 6, 2003 | 09:12 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Default Re: Modifying a Toyota engine? 2F2F Style (Monty)
Mistakes cost money, sure hope he has some :). Years ago I did the same thing but was more fortunate. Running my SS 396 Chevelle through the gears, I was speed shifting from 2nd to 3rd at about 6,000 rpm and hit first instead. Except for scaring the poop out of myself and a flat spot on the rear tires, no damage was done :).
Old Jun 7, 2003 | 03:04 PM
SloRvette's Avatar
SloRvette
Cruise-In VII Veteran
Default Re: Modifying a Toyota engine? 2F2F Style (DOCTOR J)
Couple of cans of brake clean, roll of duct tape, some JB weld, good as new. :jester
I can't remember many people messing up motors that bad. That's right up there with the turbo Buick "Drove over the crank club" members photos.
Old Jun 7, 2003 | 07:18 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Believe it or not these used to be pistons
:eek: Man did he ever screw that thing up :eek:
[Modified by SmokedTires, 7:19 PM 6/7/2003]
Old Jun 7, 2003 | 07:48 PM
71coupe's Avatar
71coupe
His parents will be very upset
Old Jun 9, 2003 | 08:23 AM
screeminmeanie's Avatar
screeminmeanie
Default Re: Modifying a Toyota engine? 2F2F Style (71coupe)
That story just doesn't sound right. Wifey has an RSX-S and I went and checked. The difference in rpm's from 5th to2nd is 1500-1800. If he shifted at 7k, he'd still be near or under redline. Not to mention that 7k in 5th would be around 130 mph. Front wheel drive, drag or almost lock up the front tires at those speeds? He would probably balled the thing up. Nope, don't believe it. He probably was dropping the clutch at 7800, trying to break the tires loose.
Shoulda just drove a Vette!! :D
Old Jun 9, 2003 | 09:52 AM
ZD75blue's Avatar
ZD75blue
Default Re: Modifying a Toyota engine? 2F2F Style (screeminmeanie)
Thing its still under warranty? :jester
The leftovers in the pan... yeeeeeesh :crazy:
Old Jun 9, 2003 | 01:34 PM
Anguish's Avatar
Anguish
Default Re: Modifying a Toyota engine? 2F2F Style (ZD75blue)
Looks like he saw 2Fast 2Furious, and took what he saw 2Seriously!!
Old Jun 10, 2003 | 07:55 PM
bill mcdonald's Avatar
bill mcdonald
:skep:
I dont get it. So you are saying the RSX can go ~120 or so mph in second gear?
WTF?
Old Jun 12, 2003 | 08:36 PM
TheWacoKid's Avatar
TheWacoKid
Cruise-In II Veteran
Default Re: Modifying a Toyota engine? 2F2F Style (bill mcdonald)
:skep:
WTF?
Someone else on another board figured it out to be ~14,000 rpm by using the correct ratios...14000 rpm would kill just about any motor I can think of! :bb
Old Jun 12, 2003 | 10:11 PM
bill mcdonald
Default Re: Modifying a Toyota engine? 2F2F Style (TheWacoKid)
Yee haw! :eek:
Old Jun 12, 2003 | 11:58 PM
scorp508's Avatar
scorp508
WTF?Someone else on another board figured it out to be ~14,000 rpm by using the correct ratios...14000 rpm would kill just about any motor I can think of! :bb
The R6's engine makes power up to 15,000 I believe. :eek:
To Modifying a Toyota engine? 2F2F Style
