Any Chassis dyno tips??
Old Jun 13, 2003 | 11:20 PM
rob75383's Avatar
rob75383
Default Any Chassis dyno tips??
I just faxed in my registration to Bloomington Gold, and realized I have only 2 weeks to get my car into shape. :eek:
I plan on running her on Breathless Performance's mustang chassis dyno again, and I'm looking for some advice.
I can't remember if the runs start either at a specific RPM, or MPH, specified by the operator. Last year, I just mashed the throttle when I hit the specified point.
What method should I use when looking for the best #'s?
-Mash the pedal down and lift when I redline?
-Slowly apply more and more gas until I redline?
-Some other method??
Last year, I ran with the headers disconnected from the exhaust. This year, I plan on leaving the exhaust the same way it is on the street.
I also plan on installing my new carter fuel pump to try and rectify the problem I had with the power dropping off at high rpm (see sig for link to dyno printout pictures)
Plus I'm gonna try installing my holley adjust-a-jet kit.
I've had both the pump and the adj.-a-jet kit for at least 4-5 months (been that long since I've posted too :bb ) and I've been too busy to even take the vette out. :sad:
I'm crossing my fingers that I can AT LEAST break 300rwhp this time.
Old Jun 13, 2003 | 11:52 PM
L79vette's Avatar
L79vette
Default Re: Any Chassis dyno tips?? ('75 383 ElkGrove)
At whatever RPM you are starting the recording, go to wide open throttle immediately. Otherwise you won't see the full-power results until you do get the throttle all the way open.
Good Luck!
Old Jun 14, 2003 | 07:30 AM
Matt Gruber's Avatar
Matt Gruber
see Dyno tips in my sig/profile
good luck!
To Any Chassis dyno tips??
