Help! Engine knock
Old Jun 16, 2003 | 11:38 AM
VQT88Vette's Avatar
VQT88Vette
Default Help! Engine knock
I rebuilt my 1988 with Trickflow heads and total seal rings, with everythings else stay stock. Now the engine knock at near WOT. I had check it with a scan tool and it showed the computer does retard the timing but the engine still knock. The highest Octane I can get around here is 91 Octane.
What do I need to do to correct this problem?
Thanks in Advance
Old Jun 17, 2003 | 05:54 AM
71coupe's Avatar
71coupe
Default Re: Help! Engine knock (VQT88Vette)
MSD sells timing retard boxes that work with their MSD units - 6A, 7AL, etc. Their timing control boxes also have this feature.
You install a microswitch on the carb linkage, adjusted to close at WOT. NOS sells a good microswitch that would work well.
On the control box, you plug in modules for how much retard you need (from 1 deg to 12 deg)
Here is a link to their pdf download for their regular timing computer. It talks about hooking up a switch for "high RPM retard"
http://www.msdignition.com/pdf/8980_tc.pdf
Old Jun 17, 2003 | 10:58 AM
VQT88Vette's Avatar
VQT88Vette
Default Re: Help! Engine knock (71coupe)
Will the adjustable fuel pressure regulator work to eliminate this problem instead of playing around with MSD box?
Thanks,
To Help! Engine knock
