700R4 question?
Old Jun 16, 2003 | 09:07 PM
JUAN J SANCHEZ's Avatar
JUAN J SANCHEZ
Default 700R4 question?
I need opinions. I have a built 700R4 for my 89 with a 475-500hp 383 maxing out at around 6000rpm. I know my 700R4 might not live long behind this motor but it's what I have for now. I have a Art Carr 10" non-lock-up convertor and I'm thinking of going to a lock-up convertor or maybe using a TH400 like I did on another C4 project. If I use a TH400 I'd have to keep the 2.73's in the rear because I will be driving on the highway often,with the 700R4 I'd install 3.54-3.73's to give me around 120mph@6000rpm @ the traps. Anyway, does anyone out there have a 700R4 that's lived behind this kind of power and how long has it lasted? lock-up worth anything? Or should I go TH400 and not worry about a trans and worry about the D36? :confused:
Old Jun 17, 2003 | 09:32 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: 700R4 question? (JUAN J SANCHEZ)
I have a 700R4, that the builder says, should be good for 700+ HP. I am using a Vigilanti 2600 rpm stall lock-up converter in front of it. So far it has only been abused by a Crossfire. The old trans was shot, and I have more HP sitting on an engine stand. I race every week and of course it's holding up fine. They had to "de-tune" it so I could live with it until the HP transplant. *I* think this is the best way to go for a dual purpose vehicle. More stall will be needed with the new engine. Good luck, and...
RACE ON!!!
1984 Crossfire
Member NHRA
Old Jun 19, 2003 | 09:34 AM
Jvette73's Avatar
Jvette73
If you want a better O/D tranny consider the 2004r. It can be built to handle that kind of power. Its a better trans then the 700. Its lighter and robs less power and has a better grear spread. All 200's have full throttle 3rd 4th ushift and hold in 4th. The turbo buick guys have brought the 200 a long way over the years. my bros turbo T has 500+hp and the 200 hold up good. Plenty of billit internals available for it. Check out the trans talk section on the http://www.turbobuick.com. Those guys have the mose expierence with the 200.
if you want to go TH400 talk to me. I have the original one from my 73. Its ready to go as is and works great, but you would likely want to tear into it anyway.
Old Jun 19, 2003 | 12:03 PM
gkull's Avatar
gkull
Default Re: 700R4 question? (Jvette73)
Your way low on power to worry about a well built 700. Mine has the 850 hp upgrades.
I bought the Art Carr 3500 stall lockup three clutch 9.5 inch with 4.11 rear gears and I can go @ 130 mph in third with 28 inch tall tires
Old Jun 19, 2003 | 07:39 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Your 700R4...after a good Hi Performance build up should be OK....for what you ask it to do....
tony
:thumbs:
To 700R4 question?
