Electric Vacuum Pump, what gives???
Old Jun 19, 2003 | 01:13 AM
TrueBlue ChevyDude's Avatar
TrueBlue ChevyDude
From: Brandywine, Chester and Ridley Valleys Pennsylvania
Default Electric Vacuum Pump, what gives???
OK, if they worked so well, everyone would be running one. I was thinking of trying one to keep power brakes on a 246/248 .522"/.525" 110 cam in an '88 4 speed 360 cid, Comp Cams tells me to expect 9-10" of vacuum at 1000rpm what are the problems associated with these pumps? What's the current draw? Would I be better off going with the power-steering fluid conversion kit? Or am I doomed to a vacuumless right-leg workout at every stoplight? :chevy
Old Jun 19, 2003 | 07:35 PM
dsagers's Avatar
dsagers
Default Re: Electric Vacuum Pump, what gives??? (TrueBlue ChevyDude)
Go with the Hydra Boost and never look back!
Then get an electric headlight conversion: http://www.corvetteactioncenter.com/...threadid=24290
