FLAME or MSD
Old Jul 31, 2003 | 10:11 AM
1977's Avatar
1977
Default FLAME or MSD
Hi Guy's and Gal's I am going to up grade my Ignition on my 383 and was going to the Flame Thrower Distributor but my local Scam Charger store say's that will not perform as good as a $500.00 MSD kit with a 6al. Just would like some input if the MSD is that much better thanks :rofl:
Old Jul 31, 2003 | 01:34 PM
gkull's Avatar
gkull
Default Re: FLAME or MSD (1977)
Go digital multi spark. I have the mallory unilite with vacuum advance, Taylor 10. something mm wires, Crane H6R multi spark and super coil.
Very trouble free.
Old Jul 31, 2003 | 02:44 PM
norvalwilhelm's Avatar
norvalwilhelm
Default Re: FLAME or MSD (gkull)
George I had troubles this summer with my unilite pick up and had to get a new one for $172 plus they sell a volt surge protector for in the line for another $50 or so.
I have 4 MSD units piggy backed onto each other without problems plus a Accel super coil
Old Aug 1, 2003 | 10:21 AM
gkull's Avatar
gkull
Default Re: FLAME or MSD (norvalwilhelm)
I have been using the same Unilite body since the late 80's. Mallory has always been good to me. When I need to have a different advance courve they do it for free. I have had only one modual die in all these years. I do use a ballast resistor to limit voltage just like the installation calls for.
I'm running 11.2 compresion with .055 spark plug gap and I have had flawless ignition into the rev limiter at 7500 rpm. Never again would I use junk like MSD 6AL's
Old Aug 1, 2003 | 11:13 PM
Jvette73's Avatar
Jvette73
Might wanna check these guys out. They can build a dist to you exact specs. Helped my neighbor put one on his 73 cuda recently. Nice unit. they make them for many makes of vehicles by grafting the HEI top portion to the bottoms of other manufacturers. If you see an HEI in a Toyota, you know where it cam from. Of coarse they do the GM models too.
http://www.performancedistributors.com/gmdui.htm
To FLAME or MSD
