Gapless Rings and PCV system
Old Aug 1, 2003 | 06:31 PM
GRX's Avatar
GRX
Default Gapless Rings and PCV system
When running gapless rings, does the PCV system need modification? ...since there is less blowby. 1985 L98 - TIA
[Modified by GRX, 3:33 PM 8/1/2003]
Old Aug 1, 2003 | 10:51 PM
arnold's Avatar
arnold
Default Re: Gapless Rings and PCV system (GRX)
You need not worry that the oem PCV system will generate too much vacuum in the crankcase. Besides, how much vacuum is generated by the oem PCV system during WOT?
