It was a bent valve
Old Aug 22, 2003 | 11:32 AM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default It was a bent valve
After trying a few tuning ideas I did a compression check on #1 and the gauge did not move :nonod: So I pulled the head off and the exhaust valve is bent. I talked to the guy who does my head work and he said he can have it done today.
Old Aug 22, 2003 | 11:54 AM
632C2's Avatar
632C2
Default Re: It was a bent valve (69 N.O.X. RATT)
John, I must be missing something. What happened?
Steve
Old Aug 22, 2003 | 12:21 PM
69 N.O.X. RATT
Default Re: It was a bent valve (542C2)
Hey Steve,
See my post about wierd valve trane issues in this (engine mod) section. It is about half way down the page.
Old Aug 22, 2003 | 01:14 PM
gkull's Avatar
gkull
The only way to bend a valve is piston impact. Valve float is very destructive. Generally todays forged pistons have such deep out of the box valve pockets that you would have to have massive lift before you even have to worry about piston/valve clearance issues.
If you had the motor/heads proffessionally done I'd be on them about inccorrect spring pressures. The other thing is good sequential misfire rev limiters are worth there weight in gold. I like my Crane 6-R
Old Aug 22, 2003 | 01:23 PM
69 N.O.X. RATT
Default Re: It was a bent valve (gkull)
George, see the same post I referred Steve to, it was sorta a freak thing that happened. You correct about the piston to valve contact issue.
Old Aug 22, 2003 | 02:16 PM
66427-450's Avatar
66427-450
The only way to bend a valve is piston impact. Valve float is very destructive..........The other thing is good sequential misfire rev limiters are worth there weight in gold. I like my Crane 6-R
agree, i'd look real hard at ALL your valves/springs (including your choice of springs/related hardware, and clearances..... one cylinder had a problem, why shouldn't another later??... keep looking till you come up with a root cause ! (you were lucky this time, consider it a warning)
AND regarding the rev limiter, I totally agree! , great investment if you're going the race (you know how it is during the "heat of battle" :-)
:seeya
[Modified by 66427-450, 2:19 PM 8/22/2003]
To It was a bent valve
