Roller Lifter Tight Fit!!
Old Sep 1, 2003 | 08:59 PM
GRX's Avatar
GRX
Default Roller Lifter Tight Fit!!
Has anyone ever had roller lifters seize in the bores? I'm worried...my Crane roller hydraulic lifters seem a bit tight when going in. Block is a new, standard lifter bore, bow tie block. Any input appreciated.
Old Sep 1, 2003 | 11:07 PM
gkull's Avatar
gkull
Default Re: Roller Lifter Tight Fit!! (GRX)
BT blocks need lots of work before being used!:( Everything is custom. You need to hone out the lifter bores. I repeat everything on them is not done. I do Sprint car motors and they take 30-40 man hours to do what you want.
When you get into race blocks they expect you to work on them :flag
Old Sep 1, 2003 | 11:42 PM
GRX's Avatar
GRX
Default Re: Roller Lifter Tight Fit!! (gkull)
I know. I've spent a pretty penny at the machinist preping the block. The GM specs on this block indicate a finished lifter bore...ready to go.
[Modified by GRX, 8:48 PM 9/1/2003]
Old Sep 2, 2003 | 10:09 AM
gkull's Avatar
gkull
I'd talk to your machinest. Lifters should just slide in with a little lube. that's why I was thinking that a lifter bore hone and just open them up a .001 or so.
I was also just thinking you probably have everything together already and perfectly clean - I've had to take apart one of my stroker motors because I didn't grind enough to allow for crank shaft end play. I almost went into depression!!!!!!!!!!!
Old Sep 2, 2003 | 10:25 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
you can lightly hone the lifter bores with a brake cylinder hone to smooth the finish :chevy
[Modified by clem zahrobsky, 10:26 AM 9/2/2003]
To Roller Lifter Tight Fit!!
