Ring end gap ?????
Old Sep 10, 2003 | 03:40 AM
gkull's Avatar
gkull
Default Ring end gap ?????
I was just doing some JE rings. Normally I just do a .030+ a few. These boxes of JE's ask for .040 top and .050 second ring end gap. Chromoly face 1/16 and d- iron 1/16th second.
This is for a motown 427 small block 4.125 X 4.00
Nothing but problems with Bill Michell Products.
Old Sep 10, 2003 | 07:03 AM
DeenHylton's Avatar
DeenHylton
Default Re: Ring end gap ????? (gkull)
George,
Are you stepping-up or is this for someone else? Different pistons have different thermal expansion rates. Try running a set of hypereutectic pistons...you can drive a Mac-truck between the top end-gap settings. :lol:
Deen
Old Sep 10, 2003 | 11:50 AM
632C2's Avatar
632C2
George, I am looking at the "Ring Installation Guidelines" that came with my JE pistons/rings. For "High Perf.Street-Stip" it shows a minimum gap of .0045" * bore for the top ring and .0050" * bore for the second ring.
On your 4.125" bore block this would amount to a minimum of .019" end gap for the top ring and a .021" for the second ring.
Steve
Old Sep 10, 2003 | 11:51 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
That sure seems huge. I'm looking at my instruction sheet for my last JE/SRP rings and they show the alrgest possible combination being .0065 per inch for Chrome Moly ones even in blown or nitrous race deals. And everyone places them a little conservative and say even that is too loose. That only comes up around .027-.028 for the top and the second one at around .022-.024.
Are these some whiz bang high tech things? Sounds like they really subscribe to the large second gap theory!
JIM
Old Sep 10, 2003 | 10:06 PM
CFI-EFI's Avatar
CFI-EFI
End gaps of .040-.050 are HUGE. If that is really what it says, I'd be on the phone with J&E. The other numbers, .0045, etc, usually are a spec, more of a guide line, pertaining to the amount of gap per inch of bore diameter. A nominal. .004" gap per inch of bore equals a .016 gap on the subject ring, in a 4" bore. This is much closer to where you want to be. Re-read, both of you, and check other sources of info. .040 is about double what you want. .004 will seize the engine, in a heartbeat. Good luck, and...
RACE ON!!!
Old Sep 11, 2003 | 03:07 PM
427Hotrod's Avatar
427Hotrod
Default Re: Ring end gap ????? (CFI-EFI)
You got my curiosity up some so I looked at some other ring info I had and I found some Speed Pro stuff that showed up to .009 per inch in ungodly blown/nitroused deals. That might put you around .037 or so, but I would really have to have a good reason to go that big. I suppose if I was running it on the edge of meltdown for a few seconds at a time and I knew the gaps would close up when pistons started glowing....maybe.
I'd be interested in what JE says. In fact their ring packaging sure looks like Speed Pro stuff anyway!
JIM
Old Sep 13, 2003 | 03:08 AM
gkull's Avatar
gkull
Default Re: Ring end gap ????? (427Hotrod)
We ended up doing .030 on each. This 427 motown small block is going to see lots of abuse. It's got lot's of good parts. We spent a good 6 hours just clearancing the 6 inch H beam rods and the threaded ends of the bolts.
Motown blocks are really nice units. The problem was the Comp Cams 1.050 base circle cam. My last Crane billet roller was only .950 inches. That's a full .100 difference that has to be made up by grinding off one side of every rod and a small amount off every rod bolt.
We had each piston in and out many times and just when we thought we had enough clearance when we went to the final 79 foot pounds of TQ on the rod bolt two more just gently touched the cam. So it was back out for more grinding to get at least .050 clearance on every one.
4 inch stroke small blocks with 6 inch rods are very custom built motors.
To Ring end gap ?????
