Question on roller rockers?
Old Sep 20, 2003 | 09:35 AM
vincevette's Avatar
vincevette
Default Question on roller rockers?
I'm thinking of changing out my 1.5 roller rockers to 1.6. tThe lift on the cam is 540. My question is what will it change the lift to. Thanks for you help and knowledge, Vince :cheers:
Old Sep 20, 2003 | 10:31 AM
CFI-EFI's Avatar
CFI-EFI
Default Re: Question on roller rockers? (vincevette)
This is simple arithmatic. If the lift at the valve is .540" with a 1.5:1 rocker arm, the cam lobe lift, is .540"/1.5=.360". A cam with a .360" lobe lift times a 1.6 rocker arm ratio (.540 x 1.6 = ) equals a lift, at the valve of .576". Amazing how that works...HUH?
RACE ON!!!
[Modified by CFI-EFI, 3:18 PM 9/20/2003]
Old Sep 20, 2003 | 02:20 PM
Taijutsu's Avatar
Taijutsu
Default Re: Question on roller rockers? (CFI-EFI)
A side benifit of rollers is reduced temps!
Old Oct 3, 2003 | 07:36 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
I found a great answer from 84 GrandSport on the Digital Corvete forum. http://www.digitalcorvettes.com
Excellent help.
Use to be on this forum but left.
Check it out.
Helped me.
tony
:flag
[Modified by oldace84, 4:36 PM 10/3/2003]
Old Oct 8, 2003 | 08:16 PM
chucks88's Avatar
chucks88
Default Re: Question on roller rockers? (oldace84)
Check it out.
He's Back
Yoslambo1
To Question on roller rockers?
