Valve Lash too tight?
Old Sep 23, 2003 | 01:32 PM
GRX's Avatar
GRX
Default Valve Lash too tight?
On a solid lifter engine; what are the signs? Backfire?
Old Sep 23, 2003 | 05:39 PM
vettewine's Avatar
vettewine
Default Re: Valve Lash too tight? (GRX)
Backfire, rough idle, not enough lifter noise, etc. Better check them to be sure as you sure can burn your valves very quickly if not corrected!
:sad:
Old Sep 25, 2003 | 10:32 PM
88-406's Avatar
88-406
St. Jude Donor '05
Poor idle and low vacum
To Valve Lash too tight?
