L-98 Crank weight ?
Oct 1, 2003 | 05:11 PM
St. Jude Donor '11, '14
L-98 Crank weight ?
I am considering buying a lightweight crank for a bottom end rebuild. I would like to know what the stock crank weighs to try and figure out what I really will be saving buying a lightweight one.
TIA<
Robin
:cheers:
Oct 2, 2003 | 02:53 PM
Re: L-98 Crank weight ? (zrracer)
50 lbs.
Oct 2, 2003 | 03:41 PM
Re: L-98 Crank weight ? (Greenvette)
Robin
:cheers:
Oct 2, 2003 | 05:53 PM
My SCAT 4340 3.75 stroker came in at 53.5 pounds...
Oct 2, 2003 | 08:53 PM
Re: L-98 Crank weight ? (No Go)
So, a stock crand would be around 85 lbs?
:cheers:
Oct 3, 2003 | 01:29 AM
:eek: Thats pretty heavy, how much does the short block engine and the entire engine with all the acc's bolted on weigh? 600lbs? :confused:
Oct 16, 2003 | 03:55 PM
I believe he means 50 pounds for the stocker
Oct 17, 2003 | 11:00 PM
Re: L-98 Crank weight ? (Ruby6spd)
I ordered one yesterday. I got a 34 lbs. one. I can not wait to see the difference in the car.
Robin
:cheers:
