Rod Bolts
Old Dec 15, 2003 | 09:27 PM
00fxd's Avatar
00fxd
Default Rod Bolts
I know this isn't the right thing to do but has anyone ever installed new [hi strength] rod bolts with out resizeing the big end after? sb 400ci.
Old Dec 16, 2003 | 06:25 AM
DeenHylton's Avatar
DeenHylton
Default Re: Rod Bolts (00fxd)
I wouldn't do it ...unless you really want to spin a bearing or sieze the crank. Either way it will be MUCH more expensive than spending the $80 or so to get the rods resized.
Deen
Old Dec 16, 2003 | 09:11 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: Rod Bolts (DeenHylton)
Deen
:iagree:
Old Dec 16, 2003 | 09:31 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
i have changed many rod bolts without reconditioning. i have a steel plug that is 2.225 dia that i put into the big end,torque the original bolts to spec and the remove 1 bolt and replace it with the new one,torque to spec and then do the same to the other bolt. you should do this in a rod vise.
Old Dec 18, 2003 | 04:15 PM
ram82fire's Avatar
ram82fire
Default Re: Rod Bolts (clem zahrobsky)
The motor man gives good advice once again,,,,,, :yesnod: :yesnod: :yesnod:
geo
Old Dec 19, 2003 | 12:54 AM
00fxd's Avatar
00fxd
Default Re: Rod Bolts (ram82fire)
Thanks guys. I thought so but I was hoping to hear that it could be done.
To Rod Bolts
