C5 cam/lifter/rod???
Old Jan 9, 2004 | 03:54 AM
AZGASSER's Avatar
AZGASSER
Default C5 cam/lifter/rod???
I am looking to have a Comp Cam .581/.588, Duration - 224/227 at .050, and LSA - 114 degrees installed with the stock heads on my O3 Vette. This will flow through StainlessWorks long tube headers and high flow cats. I am planning on upgrading my springs due to the high lift of this cam. Should I look into changing the lifters with the new cam, since the original ones are mated to the stock cam? Also, should I change the push rods as well? Any HP guesses with this set up? I am making 335 RWHP before the cam. Thanks for all your great info and help!
Old Jan 23, 2004 | 10:14 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: C5 cam/lifter/rod??? (AZGASSER)
no need to change roller lifters when changing a cam. i would buy a complete kit from CC,cam,springs,retainers,keys and pushrods. :chevy
