New 3 valve heads!
Old Jan 12, 2004 | 08:03 AM
Matt Gruber's Avatar
Matt Gruber
Default New 3 valve heads!
http://www.corvettec5.comC6/GenIVHeads-1-sm.jpg :party:
[Modified by Matt Gruber, 8:06 AM 1/12/2004]
Old Jan 13, 2004 | 03:15 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Re: New 3 valve heads! (Matt Gruber)
:cool:
Old Jan 13, 2004 | 11:07 AM
gkull's Avatar
gkull
I'm pretty sure that's the same company that has made the 4 valve push rod heads.
They are just so expensive that they are hard to justify.
Old Jan 13, 2004 | 01:41 PM
MarkBychowski's Avatar
MarkBychowski
Default Re: New 3 valve heads! (gkull)
Aren't these the ones GM is working on for the new Z06 replacement version of the C6?
Old Jan 13, 2004 | 05:40 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: New 3 valve heads! (MarkBychowski)
here's another pic:
[Modified by Twin_Turbo, 5:19 PM 1/13/2004]
Old Jan 23, 2004 | 10:09 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
you will see these on the trucks before the corvettes but the corvette will get them. ford already has 3 valve heads on their 04 trucks so chevy is playing catchup. this setup with a short pushrod to operate the exhaust valve was used on a 1939 BMW :chevy
Old Jan 28, 2004 | 08:34 PM
64_365's Avatar
64_365
Default Re: New 3 valve heads! (clem zahrobsky)
Didn't 427 SOHCs use a short pushrod as well?
Old Feb 5, 2004 | 04:40 PM
2manyfuncars's Avatar
2manyfuncars
Default Re: New 3 valve heads! (64_365)
So do Alfa V-6's.
Old Feb 12, 2004 | 02:30 AM
Solid LT1's Avatar
Solid LT1
NO! they used direct actuated roller rocker arms that limited maximum lift to below 0.700" (I think the Crane "Nitro 660" cams were some of the biggest Cammer grinds ever made (0.660" lift.) I am also looking at the intake manifold on this LS? NO WAY will it fit under a Vette hood! Must be a truck engine.
[Modified by Solid LT1, 11:32 PM 2/11/2004]
Old Feb 13, 2004 | 01:53 AM
korvetkeith's Avatar
korvetkeith
Default Re: New 3 valve heads! (Solid LT1)
Motor Trend was claiming this month that the 3 vavle would end up in the Z06. FWIW
Old Feb 13, 2004 | 02:04 AM
tapio's Avatar
tapio
What´s the big deal about 3 valve heads? Check this out:
http://www.speedoptions.com/articles/2327/
Pretty cool, I think!
Old Feb 14, 2004 | 03:49 PM
Powerdrive's Avatar
Powerdrive
I think it looks prone to failure...It looks like it belongs on a 39 bmw.This is 04, Im sure someone can do a better job than that.I guess it will work for a retro fit ...but why bother.I doubt you can rev it very high. But hey least someones is thinkin huh :crazy: That exhaust pushrod is what realy looks stuck in there
To New 3 valve heads!
