Ford Type "F" Trans Fluid?
Old Jan 20, 2004 | 05:29 PM
8T1-7T9 BIONIC VETTE's Avatar
Default Ford Type "F" Trans Fluid?
The mech who built up my 700R4 Trans for racing also worked for a major player in racing trans technology.
He told me if I wanted a crispy gear change I should use Ford Type "F" trans fluid since it applies more pressure to the clutches with minimal slippage.
I was wondering if any of you guys out there are running the Type "F" fluid and how much more bang into second gear are you getting?????? :steering:
Old Jan 20, 2004 | 11:24 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Ford Type "F" Trans Fluid? (8T1-7T9 BIONIC VETTE)
i run 50 50 mix dexon and type f :cheers:
Old Jan 20, 2004 | 11:55 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I've used Type F in serious rebuilt trans with the good linings on a regualr basis. For lack of a better description, the old Type F is considered to be a "High Impact" fluid and Dexron was a "High Lubricity" fluid. Originally it had to do with the type of friction materials used, but most aftermarket stuff accepts Type F just fine.
Can you really feel it? I doubt it, but the most impotant thing is how the linings like having a less slippery fluid when they apply. That has to add up to a slightly firmer shift along with less slippage and heat.
I would use it in your trans.
JIM
Old Jan 21, 2004 | 12:19 AM
Default Re: Ford Type "F" Trans Fluid? (427Hotrod)
JIM
Thanks,
That's about how he explained it....Second will cause the tires to break loose when it up shifts. Sounds good when second breaks the tires....like it was a standard upshift. :steering: :thumbs:
Old Jan 21, 2004 | 06:49 AM
comp's Avatar
comp
the ATF+3 also works
Old Jan 31, 2004 | 01:32 PM
Ironcross's Avatar
Ironcross
The same thing as B&M`s trick shift fluid. :thumbs:
Old Jan 31, 2004 | 08:00 PM
Default Re: Ford Type "F" Trans Fluid? (Ironcross)
:iagree:
B&M Trick Shift Fluid= $4.95 a Quart
Ford Type "F" Trans Fluid= $1.05 a Quart
B&M Trick Shift Fluid= Expensive Trick :eek:
Old Feb 2, 2004 | 08:44 AM
comp's Avatar
comp
to change the dye color cost's $$$ :lolg: :lolg:
To Ford Type "F" Trans Fluid?
