Cam Help/Advice
Old Feb 16, 2004 | 05:10 PM
piratemike's Avatar
piratemike
Default Cam Help/Advice
Hello Everyone,
I am putting together a mild 350 for my 72' Vette. It is a 350(std bore,about 8.5 comp, mildly ported 487x heads(76cc),performer intake,headers,etc. Anyway, I am considering a Comp Cams XE256 cam and I was wondering if any of you have used this cam and if so, what did you think of it. Also, if anyone has another suggestion for the cam, I would love to hear it.
Thanks,
Mike
Old Feb 17, 2004 | 02:38 PM
gkull's Avatar
gkull
Default Re: Cam Help/Advice (piratemike)
With such low compression you need a cam that will trap pressure like these Crane power max cams.
http://www.cranecams.com/?show=brows...tType=camshaft
or for more performance
Old Feb 19, 2004 | 12:59 AM
ghostrider20's Avatar
ghostrider20
I would run at least 10.0 compression. Why not?
If you are not into solid cams, there are some great OEM hyd cams. But I would consider the LT-1 cam.
Hey, it's a vette, not a station wagon.
Mark
Old Feb 22, 2004 | 06:09 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
For max torque on low compression 350 try an Isky - ISKENDERIAN
Grind No./Type: 262-SUPERCAM, HYDRAULIC Low/Mid-Range performance cam. 9.5:1 compr. 3.08-3.70 axle ratio. Passenger cars & trucks. Up to 625 CFM Carb. RPM-Range: 2000-5500 Valve Lift - INT: .435 EXT: .435 Valve Lash Hot - INT: .000 EXT: .000 ADV Duration - INT: 262° EXT: 262° .050 Duration - INT: 208° EXT: 208° Lobe Center: 108° :thumbs:
To Cam Help/Advice
