head opinion needed
Old Feb 20, 2004 | 09:56 PM
neverendingproject's Avatar
neverendingproject
Default head opinion needed
do you guys think a 200cc intake port would be too big for a mild 355? im kinda worried about port velocity and bottom end.
the car is fuel injected if that makes any difference. cams slightly larger than gm's hot cam.
Old Feb 20, 2004 | 10:44 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: head opinion needed (neverendingproject)
too much for a mild 355 but for a warmed up one with gears it would work try and keep port down to 180 cc if you want mild :cheers:
Old Feb 21, 2004 | 07:14 PM
neverendingproject
Default Re: head opinion needed (CORKVETTE1)
thanks cork,
the heads are actually brodix 197cc's. i wanted afr comp ported 180's w/ the vortec intake port. of course , even though AFR advertises them , they dont @#$%@ sell them and wont till the end of this year. brodix does though , with comparable flow, but their bigger ports.
i guess what i should have asked is, whats it gonna hurt to run these heads? how bad?
Old Feb 29, 2004 | 09:31 PM
69stingray's Avatar
69stingray
You can always use the real "Vortec" heads. Plenty of port velocity, still respectable flow. You may want a dual pattern cam becuase the exhaust ports don't flow so well. Edelbrock also make "Vortec" style heads in 170 and 200 cc port sizes.
Old Mar 3, 2004 | 08:17 PM
neverendingproject
Default Re: head opinion needed (69stingray)
actually, that was the original plan. was gonna vortec the 85. got the intake heads, and all. now, im going aluminum on the 85, but i didn't want to buy another intake..
the vortecs are going to good use though, putting them on the 80 shortly.
the brodix heads are on the way. id still like to know how bad, if at all, the bigger ports will affect bottom end?
Old Mar 4, 2004 | 11:25 AM
CFI-EFI's Avatar
CFI-EFI
They will probably reduce low rpm torque. They're likely to have sluggish throttle response below 3000-4000 rpms. Lack-luster around town performance. Good luck, ane...
RACE ON!!!
Old Mar 4, 2004 | 01:04 PM
SWCDuke's Avatar
SWCDuke
Default Re: head opinion needed (CFI-EFI)
LS1/6 heads have considerably larger than 200 cc ports and they don't suffer from lack of low end torque.
The requirement for FI and carbureted engines are very different (and the original poster said the engine has EFI). With a carbureted engine high port velocity is necessary to achieve good fuel vaporization and distribution. On an EFI engine even fuel distribution and good atomization to promote rapid vaporization are part of the deal.
For an EFI engine, free flowing heads and a moderate cam will provide excellent torque bandwidth and very good peak power.
Duke
Old Mar 4, 2004 | 10:45 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Default Re: head opinion needed (SWCDuke)
That is a great point Duke, I never thought of that.
Old Mar 5, 2004 | 04:01 AM
71coupe's Avatar
71coupe
I pondered the same question a couple of years ago. I went with 200's and was glad I did. Although I should taken gkulls advise and went with 215's.
:banghead:
Old Mar 5, 2004 | 01:19 PM
LittleBoyBlu99's Avatar
LittleBoyBlu99
Duke
:cool: :cool:
To head opinion needed
