Help me plan my Procharged 350 project (Part1-bottom end)
Old Mar 26, 2004 | 12:50 AM
LiveandLetDrive's Avatar
LiveandLetDrive
Default Help me plan my Procharged 350 project (Part1-bottom end)
Hey guys, well this will be my first engine build, although I have done some minor stuff like a cam, intake, and soon a change of heads on my current ('77 L48) engine. I've been asking friends, reading Smokey's book, and reading what I can find online. I know there's alot of experienced people here, so I hope you can help me out!
Here's some of my general ideas for the project: It all started when I got a 2-bolt virgin (unbored, unmessed with) '78 block for $20. Rotating assembly was included too, but it is all factory cast so I have no need for it. I want to make some serious power and use an ATI Procharger centrifugal supercharger to get there (P-1SC or D-1SC). I would like some high RPMs, but nothing extreme, maybe 7500? That alone would be enough for me to figure out, but here's the kicker, I want it on the street. I drive cross country and in traffic, it is a daily driver (and will stay that way). This also needs to be as budget as possible (don't laugh )
So far I am thinking about: Scat 4340 forged crank (normal weight), Scat H-beam rods, JE forged (Nitrous?) pistons. I don't have alot of money to dump into the trick lightweight parts, but I will not skimp on the important things. All bolts will be the best. I think I will need to 4-bolt splay this block also.
1. What do you think of my choices? Scat seems to be a good, reasonably priced company. What pistons do I need exactly?
2. What little modifications can I do to these parts? I also intend to balance/blueprint everything. Is there casting flash to remove or minor modifications to the block I can do? What little things like valley screens are worthwhile?
3. Know of any C3s with centrifugal S/Cs? Links would be very helpful. I read that the D-1sc doesn't fit without a hood bubble.
Thanks alot, I will keep you all updated as I research more, and as I get into it this summer. I will ask again soon about the top end when I look more into that. Thanks everybody.
-Chris
[Modified by RUXperienced, 12:06 AM 4/1/2004]
Old Apr 1, 2004 | 01:07 AM
LiveandLetDrive
Default Re: Help me plan my Procharged 350 project (RUXperienced)
Editted and rewritten, and a bump.
Anybody?
-Chris
Old Apr 6, 2004 | 12:27 AM
69driver's Avatar
69driver
Default Re: Help me plan my Procharged 350 project (LiveandLetDrive)
I am looking into a very similar project. I have talked with the guys at Lingenfelter and they recommended the JE forged pistons if you are trying to get over 500HP. I have also talked with the guys at Procharger. They sent me there installation instructions and bracket patterns. Atleast for the 1968-72 body styles, their standard brackets will push the accessories too far out to the side of the engine bay. It will need a custom bracket. I am going to install an EFI system and the Procharger on my '69. Let me know if you find out any more info. I am still in the research phase.
Old Apr 6, 2004 | 10:26 AM
CFI-EFI's Avatar
CFI-EFI
I have no specific experience, but the short block plans are sound. Do some careful planning around your your head and piston selection. You want a tightly controlled quench area without an excessive compression ratio. That is not particularly difficult, but it does require some planning.
RACE ON!!!
Old Apr 9, 2004 | 01:21 AM
LiveandLetDrive
Default Re: Help me plan my Procharged 350 project (CFI-EFI)
Whoops, I'd given up on this thread!
69driver, thanks for the info! I definitely need to start emailing a few companies and get the manufacturers opinions. That's unfortunate about the bracket, I doubt I'll have much more luck with the '77, but what is it hitting exactly? I may go EFI later on, but I'm trying to keep the costs down now so I will probably go with a BG carb.
CFI-EFI, thanks for the suggestion, I have a general idea of how to get the quench right, but hope to learn more as I keep planning.
Thanks, anybody else? I'll put up more of my ideas for the heads, etc. before long.
Chris
Old Apr 9, 2004 | 09:00 PM
69stingray's Avatar
69stingray
The August 2002 issue of HOT ROD has an article on installing a Vortec supercharger with a carb enclosure. 627 # TQ @ 5,000 RPM & 677 HP from a 383! :cool:
My dream engine is a mild 383 w/ high flowing TPI and a Paxton supercharger. Tons of mid-range torque under the stock hood.
Old Apr 10, 2004 | 06:50 PM
96LT1's Avatar
96LT1
Definitely splay the block and go with billet caps. It will at a minimum help prevent a spun bearing and recovering from that is a cost you do not want.
To Help me plan my Procharged 350 project (Part1-bottom end)
