Need engine run stand recommendations....
Old Mar 26, 2004 | 11:51 AM
67beast's Avatar
67beast
Default Need engine run stand recommendations....
I would like to hear from you about good/bad experiences and recommendations for a SBC run stand.
Old Mar 26, 2004 | 11:58 AM
632C2's Avatar
632C2
Default Re: Need engine run stand recommendations.... (67beast)
I have been using a run stand to start up all of my engines since the early 90's. They are a great way to make sure everything is sealed up and functioning properly prior to installing the motor in the car.
Re-torqueing heads, valves, etc. is a snap. I can't think of any bad experiences. I would highly recommend one to anyone. It is one of those deals that once you use it you wonder how you ever managed without one.
Mine uses water from a garden hose for cooling purposes. I have seen some that use radiators. I might add a radiator to mine in the future.
Steve
Old Mar 26, 2004 | 07:50 PM
CFI-EFI's Avatar
CFI-EFI
Look up Dan Plett, forum name Lionsden. I believe he built his own.
RACE ON!!!
Old Mar 26, 2004 | 09:24 PM
bob's Avatar
bob
I just made up a frame that fits on my engine stand. I use a bellhousing and cooling system from an old truck I had. It is great for first run and also for getting things sorted out before install. Highly recommended.
Old Mar 28, 2004 | 08:06 PM
Lionsden's Avatar
Lionsden
Default Re: Need engine run stand recommendations.... (CFI-EFI)
RACE ON!!!
Yes, I made a run stand. A little square tubing, salvage yard radiator, electric fan and a bunch of other odds and ends resulted in the following.
Engine Test Stand
Retro hyd roller kits are way expensive. An old style 400sbc was modified to accept late model gm hydraulic roller lifters. I wanted to test run the 406 for any issues associated with the conversion. Pulling valve covers and intakes can be a real pain on a C4.
400 SBC buildup
Old Mar 31, 2004 | 08:51 AM
67beast's Avatar
67beast
Default Re: Need engine run stand recommendations.... (Lionsden)
Thanks to all for your replies. Do you have any recommendations for a run stand out there on the market that I could buy. I would like to make one, but time is short, and I would have to get help with the welding part of it.
Old Apr 8, 2004 | 10:58 PM
lowvette's Avatar
lowvette
Land-and-Sea sells a water brake dyno on a run stand. You could ask them if they're willing to sell the stand separately.
http://www.land-and-sea.com/dyno/dyno.htm
Lowcountry Corvette
www.LowVette.com
Old Apr 9, 2004 | 01:04 AM
Lionsden's Avatar
Lionsden
Default Re: Need engine run stand recommendations.... (lowvette)
Have a look at these.
http://domesticsale.com/Classifieds/1421.html
http://domesticsale.com/Classifieds/41.html
http://www.hotrodparts.com/chev.htm
To Need engine run stand recommendations....
