How Streeable is this?!?
Old Jun 4, 2004 | 10:47 PM
KyRP2NITe Corvette's Avatar
KyRP2NITe Corvette
Default How Streeable is this?!?
Okay guys,
So how streetable of a motor would this be:
Stroked LT1 to 396cid beast. using forged crank, H-Beam rods and Forged Pistons, Top Seal Rings and TPIS/AFR 54cc Heads. 58mm throttle body 30lb injectors and Crane Hydralic Roller Cam Adv. Duration 296/304 Lift .539/.558 with 1.5:1 rockers, I'm gonna run 1.6:1 Harland Sharps so lift at the valve should be .575/.595
What I am not so sure of is the Cam selection...I'm not sure if it will make power in a realistic driving condition.. I think it may be a bit much but then again she is my weekend toy!
Yes I know I am a mad man but I gotta have more power
So tell me what you think should I go with this monster of a cam or should I go a bit more mild with some thing like the Comp Cams Hot LT1 Duration 230/244 lift with 1.6:1 rockers .544/.576. I had used the LPE 74211 cam before which was basically the LT4 hot cam with a revamped ramp and duration but it has become way to tame for me.
Old Jun 4, 2004 | 11:01 PM
632C2's Avatar
632C2
Default Re: How Streeable is this?!? (KyRP2NITe Corvette)
You've got to know how I feel about it.
Steve
Old Jun 4, 2004 | 11:08 PM
KyRP2NITe Corvette
Default Re: How Streeable is this?!? (632C2)
So are you saying go for it then Steve?
Old Jun 4, 2004 | 11:48 PM
632C2's Avatar
632C2
Without hesitation. But then I am used to running cams on the street that have 300# on the seat and 850# open.
Steve
Old Jun 5, 2004 | 12:11 AM
KyRP2NITe Corvette
It's a Dam Shame you live in WA
You and I could have a whole lot of fun terrorizing the neighborhood
Yep I definitely think you're my kind of car guy.
Drive it like you stole it..... Better yet, like you rented it with insurance!
Old Jun 5, 2004 | 12:38 AM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
With deep enough gears, that cam could work on the street but 54cc heads with 396ci? I suppose it could work with enough dish in the pistons.
Old Jun 5, 2004 | 07:08 PM
KyRP2NITe Corvette
Default Re: How Streeable is this?!? (Vetterodder)
Hey good catch! I am still trying to figure that one out too. I want to run about 11:1 but the pistons I have found so far run me a little on the high side... I am waiting to get back in from sea to contact TPIS and ask if they have some 64cc heads. That would put me right in line for what I want but I might have to try tuning around the higher compression ratio, the bigger cam could help with that because the longer duration should lower the effective compression ratio felt in the cylinder. What I am Hoping is PIS/AFR has a 64cc head or maybe CNC-Motorsports can "deepen" the dish on my pistons. Thanks for pointing that out though.
Old Jun 13, 2004 | 08:45 PM
big632's Avatar
big632
You must be getting quick at changing valve springs.
Old Jun 14, 2004 | 08:52 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: How Streeable is this?!? (big632)
Not sure about the TPIS but the cam should be no problem on the street I am running almost 250 deg @ .050 duraton with over .610 lift and a 3.08 rear end on a 406 small block and I was tooling around town yestday in 4th gear at 1700 RPM no problem
Old Jun 20, 2004 | 07:13 PM
KyRP2NITe Corvette
Default Re: How Streeable is this?!? (MotorHead)
Actually I haven't had any problems with valve springs... and hey there MotorHead....that is a huge camshaft you're running. That's got to put your power band way up in the RPM range...not that it doesn't run good on the street, but wow! That thing must sing like nothing else.
Well I guess I'll find out about it first hand because all the stuff is on order now Looks like I'll be busy busy busy in August when I get back from my second med cruise this year :flag
Drive it LIke You Stole it!
Old Jun 21, 2004 | 08:42 PM
big632's Avatar
big632
I was talking about 632c2 with his spring pressures.
Old Jul 5, 2004 | 07:44 PM
OatBoy's Avatar
OatBoy
heh with those heads and that cam i smell race gas
Old Jul 6, 2004 | 08:17 PM
gkull's Avatar
gkull
The 3.875 strokers 396 ci really run nice when compared to 383 ci. At the all corvette drags in Sacramento the C-4's with slicks or ET streets were mid to high 11 second cars.
I have a rotating assembly with the 5.85 rod and Wiesco 20 cc dished pistons that would make about 10.1 c/r in a 415 ci 400 .030 over block with 64 cc heads.
With a manual tranny your Crane cam will work nice.
To How Streeable is this?!?
