Engine Assy Lube?
Old Jul 8, 2004 | 01:08 PM
ANTI VENOM's Avatar
ANTI VENOM
Default Engine Assy Lube?
I want to assemble my short block, but I know that it will not run for some time yet. I usually use engine oil on the rings and pistons before I stuff them in the hole, but I'm sure that most of it will eventually run out. What can I use to lubricate the rings/cylinder walls that will stay around for awhile?
Old Jul 8, 2004 | 04:35 PM
comp's Avatar
comp
should be fine Pre-Lube and rotate before you start
