LT4 Intake Upgrade Need Advice
Old Jun 7, 2004 | 01:42 PM
90pololt4's Avatar
90pololt4
Default LT4 Intake Upgrade Need Advice
What intakes are available that would be a great upgrade to The LT4 engine. The engine is stock-blue printed and balanced with long tube headers.
Any ideas? Thanks
Old Jun 7, 2004 | 03:22 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Re: LT4 Intake Upgrade Need Advice (90pololt4)
Just have the stock one ported.
Old Jun 14, 2004 | 07:52 PM
90pololt4's Avatar
90pololt4
Default Re: LT4 Intake Upgrade Need Advice (BrianCunningham)
Brian,
Thanks for the info. I had not even considered porting the stock unit. If I do this, should I install a 58mm TB or is it over kill?
Sorry for the delay to your response as we were out for the weekend.
Old Jun 14, 2004 | 08:05 PM
BrianCunningham
a 58 is better for overall HP, but a 52 will make for better throttle responce.
If not going with a stoker, go with the 52.
BTW
DON'T port the intake unless your also doing a match on the heads.
Old Jun 15, 2004 | 03:51 PM
MarkBychowski's Avatar
MarkBychowski
One thing you should consider is waiting on the intake until you have the time/$ to port the heads also. I decided to have my intake ported when I swapped cams a couple years ago. The intake by itself doesn't buy you much since the head ports end up being the restriction. Intake by itself might be worth 10-15HP on a basically stock configuration. In hindsight, I wish I had saved up my money and done the heads since you have to rip off a lot of the same stuff anyway.
Just something to consider
Old Jun 15, 2004 | 10:47 PM
BrianCunningham
Default Re: LT4 Intake Upgrade Need Advice (MarkBychowski)
Mark,
Nice to see you on the forum again!
Old Jun 19, 2004 | 03:16 PM
90pololt4's Avatar
90pololt4
Thanks for the info everyone. Per the SCCA SP rules the heads and intake were port matched only. The rules allow only one inch of porting into the manifold. Any other ideas? What about air filter. I cut open the top of the lid. Thanks, Rod
Old Jun 20, 2004 | 05:35 PM
BrianCunningham
Ah, your in Street Prepared me too.
Open lid is cool, pull the MAF screen too, actually you can get a plastic housing for it, that not only flow better, but don't hold the heat.
I've heard bad 7 good about smooth bore ducts, they flow more, but only if they are stiff enough not to flex shut!
Have you changed the thermostat yet?
Wired the fans so they come on sooner?
Old Jun 22, 2004 | 07:27 PM
90pololt4's Avatar
90pololt4
Brian,
The pic of your car in your signiture could be ours as well. Great looking vette!
I've done all you've mentioned & then some. Looking for more ideas to increase preformance to make up for my aging driving skills. I'm open to ideas.
Rod
Old Jun 22, 2004 | 10:52 PM
BrianCunningham
Street Prepared is all about tires and suspension & alignment.
All the shims are out, I run Hal QA1's because I also drive it on the street. I've got the Z51 swaybars, but I've got the soft base suspension springs.
Most are running aftermarket spings that are twice as stiff as Z07's
There's more about this in the racing section.
[Modified by BrianCunningham, 10:57 PM 6/22/2004]
Old Jun 23, 2004 | 07:57 PM
90pololt4's Avatar
90pololt4
The suspension is:
VBP extrme springs f&r
delrin bushings where allowed with offset lower fronts, advance design 2-way adj shocks, drilled & slotted rotrs-for weight savings, 17X12" rear wheels and 18X12" fronts with 335X17 and 305X18 Hoosiers.
Fans turn on with key on, lower temp thermostat, adj fuel regulator, long tube headers with X pipe, hurst shfiter, rollbar, hardbar crossbar, sprare tire delete, aluminum flywheel and light clutch. I'm sure I forgot something. I need more seat time and always more power- right?
If you see anything elase I need or to do please let me know.
Old Jul 5, 2004 | 11:11 AM
90pololt4's Avatar
90pololt4
Hello. Does anyone know if the Z06 intake fit the LT4? Thanks
Old Jul 6, 2004 | 01:46 AM
MarkBychowski
Nope -- completely different engine.
To LT4 Intake Upgrade Need Advice
