From: Who says "Nothing is impossible" ? I've been doing nothing for years.
The more overlap you have the less vaccum you are going to have. If you have identical duration cams one hydraulic flat tappet and one solid roller the ramps on the roller are more extreme, therefore this allows the cam to have less overlap ( and higher lift ) than the flat tappet cam.
This is the reason why roller cams are great. I can get over .600" lift with the XR280R and have the same overlap as say a CC 280H which has a lift of .480" and if you wanted .600" lift from a flat tappet you would have to get into a solid track only cam in the 270-280 deg @ 0.050" duration with huge overap that would give you very low vaccum.
I think I have it straight here anyone wants to add something that's fine Jjust trying to help out
I'm running a hyd roller w/ .520 lift. I was also concerned about vacuum,which was a big consideration for going with a roller. I'm pulling around 20 inches at idle in drive. That was more than my stock 350.
1970-Bronze. Any Flat H cam in the 230/240 range with 110 lc is not going to produce much vacuum. It will sound more like a race car with a choppy idle. 383's because of their longer stroke are more forgiving.
There are two trains of thought to make power. The cheap and incorrect way taken by most is. Put a hot cam in it! Without enough intake port flow and free flowing exhaust you end up with the race car sound that impresses all the guys at the car hang out. But it's really not a very pleasant car to drive and the gas mileage sucks.
230 intake duration cams are made to spin a 383 ci 6500 rpm and I imagine that it probably wouldn't run the best under 2000 rpm. People use crutches on motors to help them. Like 4.11 rear gears and higher stall converters. But your masking the problem of how 98% of all driving is done.
I wouldn't go above a Crane 278 power max cam in a 383 if I intended to use a F-H cam and drive the car. That will still get you over 400 hp
The builder really wanted to go with a .525/.540 - 242º/252º but my heads only support 540 lift so I backed it down. Plus I think the extra vacuum is going to be needed.
Lunati - .478/.480 - 227º/234º - 112º/108º
What do you guys think? Did I get to agressive?
I think I'm going with the PERF RPM and I'll just make it work some freekin' way.
