MSD and timing
Old Aug 7, 2004 | 04:31 PM
panchop's Avatar
panchop
Default MSD and timing
So i installed an MSD using my points and mallory hi volt coil. ( I'll be switching to an MSD distributor when the new engine goes in ) how can i take advantage of the better spark now. can i sneak in a couple more degrees of advance or should i just leave it be?
Old Aug 7, 2004 | 07:27 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
The MSD box shouldn't affect what optimum timing is. It's hotter spark does allow for wider plug gaps but I wouldn't get too carried away. The instructions show recommended gaps depending upon cr but I think they're too high in most cases. I've been running .044 gap with 10.3cr and everything is good.
