327 Holley vs Edelbrock
Old Aug 17, 2004 | 10:36 PM
Richard454's Avatar
Richard454
Default 327 Holley vs Edelbrock
Fresh rebuild 327 .30 over aprox 10.1 compression
RPM performer intake
Brodix Track 1 heads
Comp Cam XR 270 Hyd. Roller
Alum Roller Rockers
electronic ignition
Currently running a Holley 80457 600CFM carb w/ vacuum secondaries. But seems to be way too rich. Was running rich before rebuild- so I knew I was going to have to mess w/ it. Nothing has been changed as far as jets or powervalve. I was told to step up the power valve to an 8.5 (comes w/ 6.5)
I'm getting about 12+inches of vacuum at idle.
I've tried to fine tune - runs bad till warmed up-SO it looks as though I'm taking it apart -OR do I chunk it and switch to an Edelbrock 600CFM 1406?
Old Aug 17, 2004 | 11:30 PM
L79vette's Avatar
L79vette
Uhh... why haven't you changed the jets? That is the main mixture adjustment on Holleys.
No need to change the power valve, unless you are getting a lean stumble at part throttle.
One thing at a time. Get the cruise and WOT mixtures right, then attack the power valve in the unlikely event it is needed.
The power valve number tells you the vacuum at which it opens, nothing more. 8.5 is generally for a mild cam.
Old Aug 18, 2004 | 12:09 AM
Richard454's Avatar
Richard454
I guess more of my question is- Do I spend the time and money to get the Holley right( even after reading an article where drilling a hole in the throttle blades was required to idle correctly)- buying the jets and gaskets?
Or do I go w/ the Edelbrock-which from my reading/understanding is a little more forgiving and will work well w/ the intake I have.
Old Aug 18, 2004 | 05:59 AM
comp's Avatar
comp
i'd try the Holley first
Old Aug 19, 2004 | 08:28 PM
L79vette's Avatar
L79vette
Yes, tune the Holley. Either can be made to work. With your setup, either one is going to need work.
I'd also dump the vacuum secondaries with a semi-radical engine like that. I have the 650CFM Holley 4150HP race carb. Very tuneable.
Old Aug 19, 2004 | 11:12 PM
Richard454's Avatar
Richard454
Well...that's what I was thinking about the vacuum seconds. When I was having the motor built- I thought 5grand -maybe every once in a while. BUT after driving it, it's seeing 5k every chance I get!
SO you think the 4777 650CFM mechanical would be a good choice? AND get my buddy the carb expert to tune it - I'm trying to keep it streetable.
Thanks for your thoughts!!
Richard
Old Aug 20, 2004 | 11:02 AM
comp's Avatar
comp
let us know
Old Aug 21, 2004 | 11:14 AM
L79vette's Avatar
L79vette
Yes, I think the 650CFM mechanical is an excellent choice. With the right tune, it will respond instantly under any conditions.
The only thing that would compromise streetability would be if you went way too big on the carb. A 750 would not be too big, by the way. An 850 would be pushing it.
Be prepared for awful gas mileage with the double pumper, but it's probably already not stellar. I get 11MPG at 80MPH with mine, but I've got a big cam and deep gears. Who cares??
Old Aug 21, 2004 | 10:15 PM
toddalin's Avatar
toddalin
If you want to try a 650 dp with mechanical secondaries, I have one sitting on the shelf with an electric choke that works fine. (I replaced it with a modified 600 dp.) Yours for $100 plus shipping.
Old Aug 23, 2004 | 12:14 AM
Richard454's Avatar
Richard454
Toddalin-thanks for your offer. Looks like my carb expert buddy has one he's going to "give" me (he'll still owe me...)
Gas mileage? I just put gas in it when it gets to a quarter tank!
To 327 Holley vs Edelbrock
