down nozzle heads for alcohol
Mainly what is controlling the alcohol injectors?
Is this added on top of fuel, or is it the primary source of fuel?
Would you run a serious risk of hydrolock running these? Or do they only run at 4500+ rpms? I guess I just dont understand them.
I just came across them and find them very interesting.
It's mechanical FI. which is full time squirt. I've never had one hydro lock on me. From the barrel valve that controls flow to the 8 individual squirt nozzles the lines are relatively small so when the motor is shut down you don't have the volume of a whole fuel rail draining into the cylinder. Also typical shut down is to shut off the fuel and let the motor run the fuel out.
The advantage of down nozzle is: cooling directly on the valve and cylinder. Also your not impeading the column of dry air flow until the intake valve opens. The injector splash plate actually direct fuel right into the cylinder. So you have a longer injector stack of dry faster flowing air. Dry air weighing less than 8-1 methanol air has the ability to excelerate faster from a dead stop when the intake valve opens. The faster column of air keeps more fuel atomized for more complete combustion.
