Help! Does position matter on externally balanced flexplate?
Old Dec 10, 2004 | 08:37 PM
isosceles's Avatar
isosceles
Default Help! Does position matter on externally balanced flexplate?
I bought Grandsportc3's AR 383 motor. He had a Tremek. I have a 2004r, so I had to buy a flexplate for the externally balanced 400 crank. Does it matter how it is positioned on the crank? Looks like the bolt holes match up no matter how I turn it.
Old Dec 10, 2004 | 08:50 PM
CFI-EFI's Avatar
CFI-EFI
Hell YES!!! There isn't a dowel pin sticking out of the crank? Are you sure the engine wasn't internally balanced?
Have fun with the starter.
RACE ON!!!
Old Dec 11, 2004 | 12:09 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I had my externally balanced motor balanced with the flywheel and harmonic balancer. When I ground a few thou off the shoulders of my rods to clear the cam I was thinkinig I might need to get the the motor re-balanced.
Not sure about your motor but on my notor if I changed flywheels I would have to get the whole motor re-balanced and especially if I went to a flexplate for an automatic.
Old Dec 15, 2004 | 03:29 PM
71roadster's Avatar
71roadster
A good machine shop should be able to match the balance of the new flex plate to the old flywheel. Otherwise you probably have to tear it down and get everything rebalanced.
Chris
Old Dec 15, 2004 | 06:50 PM
CFI-EFI's Avatar
CFI-EFI
Chris
The balance of the part doesn't seem to be the problem. The problem is in the installation, so that the imbalance is correctly orented with the rest of the rotationg assembly.
RACE ON!!!
To Help! Does position matter on externally balanced flexplate?
