point me at a couple good cams please
Old Dec 15, 2004 | 12:44 AM
panchop's Avatar
panchop
Default point me at a couple good cams please
hyd roller for 496. 5 speed car with 390 rear. ported proline heads figure 9.5-10/1 comp. i'm trying to model it on my desktop dyno. the head mfg. recommends lift between .650-.750 so.... like to have peak HP by 6000 RPM, 6500 RPM latest. I don't want huge torque on the bottom
Old Dec 15, 2004 | 08:24 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Is the motor built already, 11:1CR would be nice for a big cam
Old Dec 15, 2004 | 08:57 AM
big632's Avatar
big632
Get one of the cams gm uses in thier 502 motors.I wouldnt go past 630lift duration around 230-240 to take away bottom torque.
Old Dec 15, 2004 | 09:09 AM
SG4206's Avatar
SG4206
The last 496 I built made peak hp at 6800 rpm , with heads that flowed 370 cfm at .700 lift. Cam was 274 / 284 @ .050
If your heads flow 330 cfm ; my guess is , you need around 255 @ .050 to make peak where you want it.
To point me at a couple good cams please
