Cleaning up block?
Old Jan 16, 2005 | 11:22 PM
ZD75blue's Avatar
ZD75blue
Default Cleaning up block?
Hey guys... I've been fooling around with polishing a bit, I'm wondering how much cleaning up should be done on oil drainbacks and such?
Maybe polishing the lifter valley, and the area around the timing chain! Probably just because I've seen what a nice finsih can look like and now raw casting isnt "Purty."
What should I do? Where should I focus?
Old Jan 16, 2005 | 11:35 PM
panchop's Avatar
panchop
go for it.
Old Jan 17, 2005 | 03:33 AM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Sky is the limit here.
Never bothered but if grinding is too slow many shops will paint the lifter valley with all kinds of stuff from plain Jane enamal to electric motor armature paint/sealer/insulator. Some will enlarge and smooth the oil drains and install screens too. Another trick is magnets epoxed in the floor of valley to catch the iron pieces of ur vlv train falling apart.
Having never done this myself i would recommend the D. Vizard book on Buget Building sb Chevys - lots great info for only $20. Or maybe Mr. Panchop will share with us how long it took to make his BB so beautiful.
As for outside cosmetics - do whatever will pushes ur pistons.
cardo0
Old Jan 17, 2005 | 09:45 AM
comp's Avatar
comp
Originally Posted by panchop
go for it.
Old Jan 17, 2005 | 10:08 AM
panchop's Avatar
panchop
lots of hours and many dremel drums but i have more time then money so....
Old Jan 17, 2005 | 10:38 AM
ZD75blue's Avatar
ZD75blue
I've got another question for you guys...
I have some pitting on the machined surfaces on the block that the main bearings sit in. Also a little around the bolt holes...
Any reason to be concerned?
Old Jan 17, 2005 | 03:02 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
PANCHOP..... You just defined that term "Over The Top"..
Hmmm maybe that is also what "they" mean when they say "Off The Hook" cause you'd have to leave your phone off the hook a longggggggggggggggggggggggg time to do all 'dat'. Couldn't be bothered with folks calling and disturbing 'yo' work.
Anyway it looks kuu-ell.
Old Jan 17, 2005 | 08:26 PM
comp's Avatar
comp
de-burr it less chance for crack's or chip's coming off
To Cleaning up block?
