How Big is too big (Intake Runners) ?
I've owned a set of Canfield heads and I had them flowed before and after some porting. The numbers on their website are misleading. Don't get me wrong they are strong heads but they CANT hold a candle to AFR's and the likes IMO.
They were going to cost me BIG DOLLARS if I wanted to get their flow numbers up to par.
You can see my flow numbers both before and after here.
http://home.comcast.net/~f12x/Canfields.bmp
http://www.canfieldheads.com/sbc_2500.html
They were even flowed on a 4.155 bore which tends to enhance numbers. The big gain you see in my chart is due to the heads being opened up to FP1206, the exhaust ports had very very little work done to them. My chart also shows how the Canfields were backing up above .500 out the box!
Look at the numbers on their website and then look at realworld numbers then decide for yourself! I traded my set for P600B kit
Been there done that boys
and if that guy Jay still works there, watch out cause him and I went round and round about why my install heights were way off from valve to valve out the box. The old saying, you get what you pay for may apply here! If you do buy some be sure to buy them direct from Canfield because I can gaurantee they'll toss excuses around when you start asking questions.
Kelvin
Tracy CA
As for the Canfields, 88-406 bought the 195's just like mine, their great up to 500 lift for flow #'s past that and they start to fall off. The 195 head is a street head ( mild street). Their 220 head will require offset rockers, the 215 head takes standard valve train componets. Oh and that Jay guy is Jay Allen who is owner of camshaft innovations. He hasn't worked at Canfield for years. John is the owner and will talk to you on the phone.
AFR's are simply over priced and the wait time is rediculous. PERIOD !! There have been plenty of people with troubles from AFR.
My main objective to offer another head to look at and express my opinion that a 215 CC head wouldn't be too big.
If you want to look elsewhere for flow #'s and not the MFG, go to chevy high performance and look in the archives, they have independent studies of flow data for ALL sbc and bbc heads.
Mike
