How Big is too big (Intake Runners) ?
TIA.
Just as a starter for a 215-220cc intake runner and provided it has good combustion chambers and good flow numbers ( 275+cfm @ .600 lift ) then you are looking at a screamer in a 383ci. I would go with a solid roller in the .600" lift range and 240-250 @ .050 deg duration. It will make peak HP in the 6500RPM range.
Weekend street driver with some grunt. Not looking for an all out tq monster to burn off the tires from a moving 60mph, but I would like to have more than the 330 rwtq I am putting down stock.
Auto transmission
3.07 geared D44
Shift around 6000-6500 MAX
383 CI
Super Victor EFI conversion
Cam 230 range @.050
Forged internals
6" Rods
Aluminum Heads
10:1 - 10.5:1 compression (92 octane gas)
What kind of suggestions would you have?
Auto transmission
3.07 geared D44
383 CI
Cam 230 range @.050
Forged internals
6" Rods
Aluminum Heads
.100" .200" .300" .400" .500" .600" .700"
67/64 119/112 177/153 226/188 265/207 281/217 285/220
I am assuming/hoping for you around 200 or less.
If so, I would say those are some great numbers.
(Also, what price are you looking at with those?)
I just don't buy this, 'everything needs to match' bs.
also, these companies DON'T tell us something useful,
'the minimum diameter, of the intake tract'.
That number, would be useful in making the correct choice of cyl head, and other stuff.
I agree with the manufacturers not giving more pertinent information, but the average Joe calling a speed shop doesn't know what he wants, and the tech guy's knowledge is generally limited.Its all about port velocity and airspeed. Due to technology advances, you can get away with running a smaller cylinder head and less cam and still run hard.
EFI with high flowing heads and a reasonable cam will make for excellent torque bandwidth, which is what street engines are about - not peak power.
Duke
I tried running some race ported Dart 230 cc. So they were more like 245+ cc on a 355 ci. They probably would have run great over 8000 rpm with 15:1 compression.The head port volume is only part of the equation. It's the total runner port volume of stopped dead air that has to get moving when the intake valve first starts to open. So a large plenum runner single plane good for 8500 rpm will make a 215cc head port react sluggishly.
I use a smaller plenum single plane on my 383 because of my 7500 rpm rev limiter.
For roller cams I'm a firm believer in the 232 - 238 max I. duration in sub 7000 rpm 383 ci motors. Keep the static compression in the 8.2 - 8.3 range. I would not buy heads with less than high 280 cfm of flow and 300+ is preferrable.
If you do go with a roller cam and 11:1 CR etc. then you will be looking at numbers like this with the Vic Jrs keep in mind peak power will be made 1500RPM above where this dyno stopped.
Lots of low end grunt there
383 CID
Intake: Super Victor EFI or Modified Victor Jr EFI conversion
Head: Victor JR CNC
Compression: 10-10.5
Tranny: 700r4
Gears: 3.07
Stall: 2500
The ability to have "street" manner and still have alot of power is due to the roller cam profile. Because of the roller lifters, the lift can be higher for any given duration over any other cam. This gives you the best of both worlds, a nice flat broad torque curve and HP that keeps climbing.
If you don't mind keeping an eye on the valve train I would go with a solid roller, I don't have any experience with EFI but I woiuld think a CC XR274R would be a good choice for a 383ci. You will see some serious power if go that route but remeber you have to be willing to check the valve lash especially when it is new it must be checked every 1000 miles or so until everthing is worn in, then you check 2 twice a year or so
As stated above the Vic Jrs are great heads and to take advantage of them you need to run a decent cam with them otherwise you are wasting them and you might as well buy a smaller head.
BTW when I was looking for heads I bought them after I read a CHP head flow comparison ( they tested about 40 of the most popular small block heads ) and they out flowed every SB head even the AFR 210 race ready which they are equal to on intake CFM and the VIc Jrs are much better on the exhaust side
This head has the best flow numbers of all the under 200cc heads. Offering great flow throughout the entire lift range you can see this head doesn’t just put up one big number at maximum lift. If you’re looking for great flow from a mid-sized cylinder head this is definitely one of the top contenders.
This is an impressive head. It features a kidney shaped combustion chamber keeping the combustion moving, the flow is awesome from 0.400-inches all the way up to our tested 0.700-inches, and the E/I ratio is an amazing 81%. We see a head that flows some serious air and likes high lift roller cams.
Here is an extraordinary head. It has larger intake ports but with 240cfm at 0.400-inches of lift who cares? The E/I ratio is an incredible 75% making it hard to find anything wrong with these heads. This head may be a little much for a mouse motor but it is perfect for a big mouse somewhere in the 383 inch range up.
Looks like he has some help with someone that knows what he's doing by looks of the dyno graph, mine was just one pull for fun when I first fired the motor up with an ailing tranny, in the spring I will get it dyno tuned with a new TKO 600 tranny and the new 1 7/8 in. sidepipes should help get the HP up there
