Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
test
Old Aug 1, 2001 | 09:54 PM
69MonacoTripower's Avatar
69MonacoTripower
5th Gear
Patrick,
You passed. Using the UBB codes heh!
Don
P.S. Did you have to re-register to do your name change?
Old Aug 1, 2001 | 09:59 PM
67's's Avatar
67's
Patrick,
Looking Good
Tom McCabe
Old Aug 1, 2001 | 10:12 PM
Juliet's Avatar
Juliet
Patrick, I may be in left field here, but are you sure it's not your old name / password cookie which is preventing you from nuking the post? I suppose it could be a preference setting Troy has set up for this forum which doesn't allow it. Usually (in the other sections C3 & C4) if you edit the first post and select delete it lets you nuke the thread if it's your own post and you've got the password right. Curious.... ~Juliet
Old Aug 1, 2001 | 10:22 PM
Troy Roberts's Avatar
Troy Roberts
CF Co-Founder
Cruise In I Veteran
Cruise In II Veteran
Cruise In III Veteran
Cruise In IV Veteran
Cruise In V Veteran
Cruise In VII Veteran
St. Jude Donor '03-'04-'05-'06-'07
We had to turn off the ability to delete your own posts as it was causing an error in the post counts. It seems that if you made a post and then deleted it multiple times the post count would actually go negative!
There is also a theory that you shouldn't be able to delete the first post in a thread since the conversation may have taken off after that and you're deleting the entire thread.
Old Aug 1, 2001 | 10:55 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
patrick were are we going to meet at carlisle? i will be there fri,and sat.
Old Aug 1, 2001 | 11:01 PM
Troy Roberts
CF Co-Founder
Cruise In I Veteran
Cruise In V Veteran
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:[/color]<HR><font face="Verdana, Arial" size="4">Originally posted by Patrick Tighe:
Troy, thanks for the heads up. Good grief, your shoulda seen the picture I was gonna post and changed my mind! Patrick
[/color][/QUOTE]
You can still edit the post to remove the pictures and such if you want.
In fact, youcan delete all of the text in a message and just put in a .
Old Aug 1, 2001 | 11:14 PM
67's's Avatar
67's
Patrick and everyone,
Zip Products is going to have a Corvette Forum area of their tent, now that we are all here, we can meet there
Tom McCabe
Clem, Tom McCabe said something about a vendors tent, can't remember who. Tom, who did you say was the vendor was? Patrick[/color][/QUOTE]
Old Aug 2, 2001 | 12:46 AM
Don O'Connell's Avatar
Don O'Connell
[B]Still can't figure out why I can't delete this.
To test
