Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Profiles Topics et cetera
Old Aug 4, 2001 | 03:51 PM
Brass's Avatar
Brass
Default Profiles Topics et cetera
Can someone help me out here? I've been using my good old CF handle 'Brass' (my old Phi Psi nickname) and I was hoping to put my real (ha ha if you believe THAT!) name al la Forum. I can't seem to figger the change from Brass to Bill. Chuckster, you've been down this road. Wanna help out a dummy?
Bill
Old Aug 4, 2001 | 04:01 PM
JmpnJckFlsh's Avatar
JmpnJckFlsh
Default Re: Profiles Topics et cetera (Brass)
I think you're cheatin' and not readin' all the posts :D
Click on "My Profile"...this software will allow you to change your user name so long as it doesn't exceed 15 characters. I am not sure it won't bust you back to "0" posts though; better now than later after you have accumated a 1000 or so posts!
Old Aug 4, 2001 | 04:02 PM
Troy Roberts's Avatar
Troy Roberts
CF Co-Founder
Cruise In I Veteran
Cruise In II Veteran
Cruise In III Veteran
Cruise In IV Veteran
Cruise In V Veteran
Cruise In VII Veteran
St. Jude Donor '03-'04-'05-'06-'07
The name 'Bill' has already been taken. Any second choices?
Old Aug 4, 2001 | 04:10 PM
Troy Roberts
CF Co-Founder
Cruise In I Veteran
Cruise In V Veteran
Default Re: Profiles Topics et cetera (Chuck Sangerhausen)
Actually Chuck, you need to have one of the administrators do it. We don't have that feature turned on for standard members.
The trolls would have a field day with it! They could flame away under a different name and then change it in a moment.
I'll be happy to make any changes for you.
Old Aug 4, 2001 | 04:11 PM
Brass's Avatar
Brass
Default Re: Profiles Topics et cetera (Troy Roberts)
The 'user name' under my profile is not a field that can be updated. Maybe I'll leave Brass. I've grown rather attached to it. Maybe I can use the other half, too: '*****'.
Bill
Old Aug 4, 2001 | 04:12 PM
JmpnJckFlsh
After you click on "My Profile", Click on "Personal Profile", where you can change all your vital data.
I believe "Full Name" actually becomes your user name, so you may not want to put in your First, Middle, and Last Names, or that will print out on your post. I tried to make some changes, and filled in my full name, and luckily it rejected it as too long.
(After Seeing Troy's Posts) Er, uh, sorry, Bill. From what I read, that's how it worked, but I was never successful at changing it (I thought it was the length). Thanks, for helping the misdirected, Troy
[Modified by Chuck Sangerhausen, 1:16 PM 8/4/2001]
To Profiles Topics et cetera
