Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
1966 header panel color
Old May 18, 2007 | 09:06 AM
egon48's Avatar
egon48
Default 1966 header panel color
what is the color on the inside of a 1966 corvette,is it zinc chromate green?
Old May 18, 2007 | 01:41 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Could be. Birdcages were primed.
Old May 18, 2007 | 03:07 PM
JohnZ's Avatar
JohnZ
If you're talking about the full-width steel reinforcement that's bonded to the underside of the front surround panel forward of the hood opening, it was dip-primed black on St. Louis-bodied cars and was green zinc chromate (just like the birdcage) on A.O. Smith-bodied cars. It required additional blackout spray on A.O. Smith cars to hide the green with the hood open, but you can usually see green from the bottom.
To 1966 header panel color
