Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Buffing Scratch
Old Aug 17, 2007 | 10:15 AM
Taq Wars's Avatar
Taq Wars
2nd Gear
Default Buffing Scratch
I have a 2007 Z06. The shop saw a scratch on the hood and "buffed" it out. Only when they buffed it (apparently with a mechanical buffing tool) they left circular marks from the buffing visible when you place it under direct lighting or look closely. (So now I have large circular marks where before there was a minor scratch.) What can I do to get rid of those tell-tale signs of the buffing? Any thoughts?
Old Aug 18, 2007 | 12:52 PM
azsparky's Avatar
azsparky
Cruising
Contact Adams polishes, they have a link on the left side of the screen or www.adamspolishes.com . I love this stuff, since I started using it my Ruby 40th Anniversary car has never looked better; just like glass.
Old Aug 20, 2007 | 09:07 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Take it back to the shop and have them get the swirl marks out. They didn't finish the job.
Old Aug 20, 2007 | 05:59 PM
Red70vette's Avatar
Red70vette
I agree with easy Mike. If they are going to buff it out it is supposed to be gone not worse.
Old Nov 8, 2007 | 09:30 PM
Nzzz's Avatar
Nzzz
Compound it out.
Old Nov 13, 2007 | 07:10 AM
vettes1st's Avatar
vettes1st
St. Jude Donor '06
Never put traditional compound on clear coat!!
Old Nov 13, 2007 | 04:15 PM
tls630's Avatar
tls630
NEVER PUT COMPOUND ON CLEAR COTE...If it is a small spot I use a little baking soda and a clean damp rag. No compound polising or rubbing on clear cote.
Old Nov 14, 2007 | 01:23 PM
Bullshark's Avatar
Bullshark
CI 5 & 8 Veteran
Not sure what you guys are talking about but I always use a 3M 05996 Perfect-It Dark Car Foam Polishing Pad Glaze after lightly color sanding the final clear coat with 2000 Micro fine wet sanding paper. Works great, just don't come anywhere near breaking through the clear coat.
Probably not a factory correct resto process, but ask me if I care.
Bullshark
Old Nov 14, 2007 | 10:53 PM
PSU 98's Avatar
PSU 98
I agree that the shop should finish their work if you're not satisfied. However, if you decide to do it yourself, you'll want to use a machine (rotary preferrably, or random oribtal buffer) with a quality abrasive polish of your choice (3M, Menzerna, etc.) to correct the 'Vette's hard clear coat. It will likely require a couple passes with various polishes and pads of decreasing abrasiveness to get the desired result.
You'll find a lot more information about it in the Car Care forum
Old Dec 1, 2007 | 06:43 AM
vettes1st's Avatar
vettes1st
St. Jude Donor '06
Perfect-it is NOT traditional rubbing compound. It is made for modern finishes.
To Buffing Scratch
