Help with paint color
Oct 28, 2007 | 06:48 PM
I am in the process of prepairing the undersire of a 1971 hood to be painted.
Can some tell me if original paint was Flat Black / Satin Black / or Gloss Black?
David
Oct 29, 2007 | 05:45 PM
I think Krylon Semi-Gloss is a good choice compared to the factory original.
Regards,
Alan
Oct 29, 2007 | 08:23 PM
Thanks Alan, I will check it out.
David
Oct 29, 2007 | 11:48 PM
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Oct 30, 2007 | 06:14 AM
Thanks for the help
Oct 31, 2007 | 07:26 AM
It is a satin black paint.I used eastwoods on mine. Worked fine.
Nov 4, 2007 | 10:04 AM
Cruise-In II Veteran
The original paint was semi-flat black.
You'll get a near perfect match with the Krylon.
Dec 19, 2007 | 06:51 AM
Quote:
Originally Posted by
Easy Mike
that's the only thing i've used for black-out areas on corvettes. i have never had anyone dispute the sheen. i understand one can buy the stuff in quarts, but i've never seen it for sale anywhere. a good friend of mine carefully open several rattle cans and dump the contents into a conventional spray gun for more even coverage on large areas. you can bet whatever GM used at the factory, it wasn't any better quality than krylon semi-flat.
