Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Radiator Support Replacement
Old Dec 22, 2001 | 09:50 PM
Bill W's Avatar
Bill W
Default Radiator Support Replacement
Got the rad support out of my 70 SB the other day. Its in such bad shape I think I'm going to go with a repro unit rather than try to repair it. It appears to me that the replacement rad support doesn't come with the bottom brackets welded on it. Maybe because the same support handled a number of different radiators? Anyway, how do I know exactly the right spot to weld the brackets? Does anyone know of a vendor that supplys a rad support with the bottom brackets attached? Thanks.
Old Dec 22, 2001 | 10:46 PM
3X2-427's Avatar
3X2-427
Default Re: Radiator Support Replacement (Bill W)
Bill---
I don't know about the 70 but both the 69 and the 67 I purchased from Dr Rebuild had all brackets in place
jer
Old Dec 22, 2001 | 11:25 PM
Mac's Avatar
Mac
Default Re: Radiator Support Replacement (3X2-427)
Jer- what happened to your signature picture? You used to have a view of those beautiful two barrels but it disappeared a few weeks ago. Maybe no-one mentioned it to you (kinda like that piece of stuff between your teeth) so I thought I'd let you know.
Old Dec 23, 2001 | 12:32 PM
Bill W's Avatar
Bill W
Thank you #1.
To Radiator Support Replacement
