Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Tcs
Old Dec 27, 2008 | 05:12 AM
DAN70's Avatar
DAN70
C1 of Year Finalist (performance mods) 2019
2017 C1 of Year Finalist
Default Tcs
Could someone post a pic of a correct TCS set up for a '70 350/350 W/AC. Part #'s would be nice also. I did a seach but found no pics. Thanks...........
Old Dec 27, 2008 | 11:55 AM
JohnZ's Avatar
JohnZ
Do you have the Assembly Manual? It shows all the wiring and vacuum components in the TCS system.
Old Dec 27, 2008 | 11:02 PM
DAN70's Avatar
DAN70
Sure do John, but sometimes a good color photo just helps to verify everything.
Old Feb 1, 2009 | 02:40 PM
dennis's Avatar
dennis
Old Feb 2, 2009 | 09:16 PM
DAN70's Avatar
DAN70
Thanks Dennis, thats beautiful. That steel vacuum line is a hard piece to find. I'd like to make one, if it's not to much to ask, could you give me the measurements of those bends?
Old Feb 5, 2009 | 07:37 PM
dennis's Avatar
dennis
I spent a couple of years researching that advance tube. It is nearly correct. The bends are right and I am in the process of finding a supplier for the double flare tube. You can get the piece right from classic tube in steel or stainless but single flare only. Tom there helped me out duplicating the piece from a known original I sent. Can't tell once the rubber hose is attached. Here's the info from classic tube
DENNIS
YOUR FRIENDS CAN ORDER THE VACUUM LINE FROM US @ $20.00 IN STAINLESS OR $15.00 IN OE STEEL USE PART NUMBER CVO1004-SS FOR STAINLESS OR CVO1004-OE FOR STEEL
TOM
To Tcs
