Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
63 Interior paint advice
Old May 18, 2011 | 07:42 PM
JAMES69's Avatar
JAMES69
Default 63 Interior paint advice
Folks,
I am redoing the interior of my 63 SWC. The color is tan. I am going to use SEM dyes on the vinyl areas. I have just found out that the interior metal trim uses a slightly different color, apparently not a dye. Does anyone know if this paint is available over the counter somewhere? Also, the "halo" requires a metallic tan paint, any ideas? Lastly, the speaker grill and the side vents are a different shade again. Where might I get this one from,
Any advice?
Thanks in advance,
Jim
Old May 19, 2011 | 12:13 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I've seen the paint codes in print. Might have been Noland Adams' Restoration Guide Volume II. I'll thumb through it this evening. Have you posted on the NCRS web site?
http://www.ncrs.org/
Old May 19, 2011 | 02:23 PM
JohnZ's Avatar
JohnZ
Try this:
http://www.tcpglobal.com/autocolorli...rolet-pg02.jpg
Old May 24, 2011 | 08:27 PM
dennis's Avatar
dennis
Don't know why people think the interior vinyl was dyed. It isn't possible to dye vinyl in the literal sense The vinyls were actually made in the color of the interior to install at assembly. Some of the hard plastic may have been colored, although I have seen those pieces molded in color as well.
However for the service and touchup of color dupont made the matching vinyl color.
This is a site with the actual color cards explaining what pieces were colored with what paint as well sheen. Hope this helps
Old May 25, 2011 | 11:32 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by dennis
...It isn't possible to dye vinyl in the literal sense...
Vinyl can be dyed. SEM automotive interior dye is an excellent product for this purpose. SEM can be used on vinyl, leather, hard and soft plastic, and metal.
A PO had gone to black on the interior in my '68. Thanks to SEM, they are now back to the original 411 dark blue.
Old May 25, 2011 | 04:06 PM
dennis's Avatar
dennis
SEM is an excellent product, but not dye in the sense that it will change/alter the color of vinyl completely. As in fabric dye or the like, will do to a porous substrate. Don't think anyone cares much about that argument.
SEM does have a superior bond to all these surfaces mentioned. To get the correct color/sheen may be a bit more problematic.
Since this post is in the factory correct section, the dupont product produces the best color and sheen to original, with a very good bonding ability. Why wouldn't it? That's what was used on the pieces to be painted at the factory.
The only issue IMO would be the seat vinyl. The factory vinyl was made in the color through and through. Don't recall ever seeing a correct car that had dupont colored seat done originally.For this reason I think the SEM is a better product.Only issue being the color match/sheen which a good body shop supplier should be able to provide
Whatever product is used the outcome will only be as good as the prep work.
To 63 Interior paint advice
