69 Stingray Resto
Where should I start looking for parts? Are there any online shops worth buying from that aren't overpriced? I've mused about going to a local junkyard or two but if I am putting the time into this car then I better put in some decent parts too. Any advice would be great. Thanks.
What do you know about the car and 69 Corvettes in general? Do you know the 69s had 427s, not 454s?
Rick Bizzoco has a very good 69 Corvette reference book. Pricey, but nice to have.
http://www.cranescorvette.com/1969_s..._guidebook.htm
Dr. Dobbins' book is also a good photo reference.
You may want to consider joining the National Corvette Restorers Society. The NCRS has publications which can help with the restoration. http://www.ncrs.org/
Are you wanting to get the car driveable or undertake a factory correct restoration? Do you and the lady intend to have the car judged in the future?
What is your mechanical skill level? Can you do most of the work yourself?
Do you have the space for a restoration? Parts removed from the car during the restoration will have to be safely stored somewhere.
Do you and she have the time? As a rule of thumb you can figure a restoration will take three times as long as you plan, and four times the estimated cost.
Do you have a 69 owner's manual? If you don't have one with the car, order a reprint and read through it. You will want the 1969 Assembly Instruction Manual (AIM). The AIM shows how the car was assembled at St. Louis and lists the original part numbers. Nice to have when you're searching for parts. Order the GM Chassis Service Manual while you're at it.
Time for you and the lady to have a talk. Restoration can be a big project. She is likely to become as busy as you.
Good luck.
All separate pieces of the puzzle that should be tackled individually.
Go to a car show. Talk to some of the owners of some corvettes there. You should get some good, personal, local advice there.
There are a lot of vendors. Get their catalogs...they are usually free and are a good source of diagrams, pictures, and of course, prices. Find out which vendors people like, then try them on for size. Seems everyone has a favorite, for many different reasons.
Lastly, this section of the forum isn't as active as others.
Go here http://forums.corvetteforum.com/c3-general-119/ introduce yourself with your original question and you should get a lot of advice.
and good luck. Have patience, it's rewarding!
here is a shot of my 4 year restoration (1989-1993) - picture taken summer of 2008
