Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Positraction or Not? (LR code)
Old Sep 10, 2019 | 10:38 AM
AndyinVA's Avatar
AndyinVA
7th Gear
Default Positraction or Not? (LR code)
Early 1970's rear end codes include AX and LR for a 3.36 ratio, but have never heard why two codes exist for the same ratio. I've also read that both AX and LR codes are Positraction. Anyway, I'm considering buying a C2 1966 L72 vehicle with later-date C3 stamped rear end "LR W 239 1". I suspect it doesn't have Positraction because it doesn't contain an "E" or other Positraction source identifier before between the date (239) and the shift number (1). Then again, in 1975 I believe they dropped the E or other source identifier.
I would appreciate information about the LR code rear, please, so I can make an informed decision. Thanks.
Old Sep 12, 2019 | 10:07 PM
gbvette62's Avatar
gbvette62
Positraction became standard in 1970, so any rear dated after 69, is going to be Posi.
AX and LR were both codes for 3:36 rears in 71-75 Corvettes, and LR was also used for 76-77 3:36's. I'm not sure why there are two different codes for 3:36, but it's not Posi verse open. This is just a guess, but it might have something to do with the side axles? Big blocks and LT-1's came with side axles that used bolts and malleable caps, while based motors had side axles with U bolts.
Old Sep 13, 2019 | 05:30 AM
AndyinVA's Avatar
AndyinVA
7th Gear
Thank you for your response and explanation. My concern had been based on my reading of “Corvettes By The Numbers, 1955-82”, by Alan Colvin, in which it’s stated that 71-74 stamps included either an E for Eaton positraction, or (-) for no positraction, leading me to believe that “no positraction” was an option. However, that doesn’t seem likely given the benefits of positraction. Thanks again!
To Positraction or Not? (LR code)
